Thick or thin sides?
0 Members and 1 Guest are viewing this topic. Read 6485 times.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
Re: Thick or thin sides?
« Reply #20 on: 16 Oct 2012, 05:06 am »
Thanx James,
In the same kind of language as my earlier quidline:
The subpanels created by a brace should not be congruent.
If practical subpanels should not be rectangles (i regularily break this guideline, as it can make a brace much harder to build, and as shown in the Tappen study yaking it to extremes is counter-productive).
dave
rajacat
  • Washington State
« Reply #21 on: 5 Nov 2012, 07:04 am »
This epic build gives a detailed account of a unique method of fabricating a constrained damping layer. This is one of the best documented and most amazing speaker builds I've run across :o. http://www.diyaudio.com/forums/multi-way/218437-3-way-active-time-aligned-constrained-layer-construction.html
« Last Edit: 5 Nov 2012, 08:30 pm by rajacat »
