FS: Unison Research S6 (new model) integrated tube amp
0 Members and 1 Guest are viewing this topic. Read 3761 times.
thuhaile
Price is $2400
Current model of Unison Research S6 integrated tube amp.
The following tubes are included in the sale:
6 Tung-sol EL 34B
2 NOS Raytheon 5814
Excellent condition, no scratches or dings. Looks great and sounds great.
The S6 uses three EL-34 tubes in the output stage per channel, connected together in a triple-parallel configuration that operates in single-ended Class A ultralinear mode. With this design, the S6 is able to supply an ample 35 watts per channel. Both 4-ohm and 8-ohm speaker outputs are available so that you can match the loudspeaker of your choice to the S6 for the best results.
The S6 was also designed with simplicity in mind. Our designs ensure that a minimum amount of components are found in the signal path, because we believe that the finest sound quality is the result of an unimpeded signal flow. This simplicity also translates to an amplifier that is more reliable and trouble-free in its operation.
For more info, go to here
http://en.unisonresearch.com/2815/s6-new/
5 stars reviews:
http://www.whathifi.com/review/unison-research-s6
http://www.tonepublications.com/review/unison-research-s6-integrated/
http://www.techradar.com/us/reviews/audio-visual/hi-fi-and-audio/amplifiers/unison-research-s6-955432/review
« Last Edit: 15 Dec 2012, 12:25 am by thuhaile »
wes_in_va
Re: FS: Unison Research S6 (new model) integrated tube amp
« Reply #1 on: 13 Oct 2012, 11:40 pm »
How much?
thuhaile
« Reply #2 on: 19 Oct 2012, 08:49 pm »
$2600
thuhaile
« Reply #3 on: 1 Nov 2012, 09:51 pm »
still available
thuhaile
« Reply #4 on: 27 Nov 2012, 12:25 am »
bump
thuhaile
« Reply #5 on: 15 Dec 2012, 12:25 am »
bump
