28b led indicator issue
0 Members and 1 Guest are viewing this topic. Read 1228 times.
kostisgva
« on: 13 Oct 2012, 04:01 pm »
Have a small issue. Just turned on a 2 months old 28b. The led indicator turns red and then instead of turning blue the led turns off. I can hear sound from the speaker though, the amp seems to work. Is the led malfunctioning or something else? Any ideas? Thank you, Kostis
  • The Demo is Everything!
    • http://www.bryston.com
Re: 28b led indicator issue
« Reply #1 on: 13 Oct 2012, 04:04 pm »
Hi Kostis,
It sounds like a simple LED issue but email Mike Pickett at Bryston to confirm just to be safe - [email protected]
james
kostisgva
« Reply #2 on: 13 Oct 2012, 04:08 pm »
Hi Kostis,
james
Thank you James, just did.
