6sn7's crackle on start up
0 Members and 1 Guest are viewing this topic. Read 6546 times.
wilsynet
Re: 6sn7's crackle on start up
« Reply #20 on: 14 Oct 2012, 09:57 pm »
Try giving the 6SN7 tubes a few good whacks on top with your knuckle.  During shipping or moving, debris can get spread around and you want to shake the debris loose.
Ralph at Atma-Sphere has recommended this in the past and its worked for me a couple of times.
skite30
« Reply #21 on: 15 Oct 2012, 01:53 am »
Ok fair enough. My portugese is a bit rusty. Putz has a different meaning in North America
« Reply #22 on: 15 Oct 2012, 01:59 am »
I afraid to ask, but what is??
Quiet Earth
« Reply #23 on: 15 Oct 2012, 02:08 am »
Just to clarify,,,,  this is something to try with the power off, isn't it? I have always read not to tap on tubes while they are on, but I am no expert.
« Reply #24 on: 15 Oct 2012, 02:26 am »
Once I tap a tube on my hand and appear a loose piece of glass inside :duh:
I will never tap a tube again.
wilsynet
« Reply #25 on: 15 Oct 2012, 03:13 am »
Yes, power off.  I've done with tube removed and with tube inserted.  But in the latter case, with power off.
skriefal
  • SLC, Utah
« Reply #26 on: 15 Oct 2012, 04:38 am »
The loose piece of glass was almost certainly already there before you tapped the tube.  You simply moved it.
« Reply #27 on: 15 Oct 2012, 04:40 am »
Something happen in the postal mail transport, it had delayed +60 days to arrive.
The carton box was more damaged than the usual.
SteveFord
« Reply #28 on: 15 Oct 2012, 09:25 pm »
Did a light tap or two cure the rice krispies?
skite30
« Reply #29 on: 16 Oct 2012, 02:46 am »
Aactually one of them hasnt made a noise since tapping it. The other one may end up in the do not play drawer.
medium jim
« Reply #30 on: 16 Oct 2012, 03:06 am »
Sounds like Kevin is keeping his paycheck!
Jim
