Peachtree Audio headamp/dacs
0 Members and 1 Guest are viewing this topic. Read 1231 times.
kwl
« on: 11 Oct 2012, 04:17 pm »
In the search for a modestly priced headamp/dac I came across a few products from Peachtree Audio - Decco65 and NovaPre.  They seem to check all the right buzzwords.  Initially I will be using a headamp/dac with some custom iems (UERMs), so it needs to have a low/no gain setting, a usable volume range and needs to be dead quiet.  Later I hope to get a full-size set of cans like the Audeze LCD-2 or HiFiMan HE-500; so, a higher gain setting might be appropriate.  Anyone have any experience with the Decco65 or NovaPre?  Compared to?  Thanks!
Sparky14
Re: Peachtree Audio headamp/dacs
« Reply #1 on: 30 Oct 2012, 02:13 pm »
I did have the Decco2. Loved it. It is a great all-purpose unit.
Also, I heard the Decco65 at THE SHOW last June and was very impressed.
