0 Members and 1 Guest are viewing this topic. Read 3331 times.
My speakers (TMM configuration) have a slanted (back) baffle (to attempt time aligning tweeters with the mids?).
My speakers (TMM configuration) have a slanted (back) baffle (to attempt time aligning tweeters with the mids?). Should my ears be at same height as center of tweeters or do I take the baffle angle (tweeter center axis extrapolated to my ears) into consideration? Yellow or pink line in picture?
No perceived problem with current height. But then again, until I heard a high end system I perceived no problems with my then low end system. I was hoping that the answer would have been the yellow line as my tweeter height is 36", about 7" or 8" shorter than my ears, regardless of chosen chair. With these speakers (Eggleston Works Fontaines, and I assume the Andras as well), I don't see how anyone can match tweeter height to their ears. I've never seen these, nor any floor standers, raised up on 8" blocks. And I'm only 5'9"! If it were an inch or two I could easily try a different height to test, but 8" is quite a difference.I'm hoping they were voiced with this in mind - tweeter lower than ears.
