FREE: Madisound Thor/Odin MTM cabinets, pick up only in Montclair, NJ till Fri.
0 Members and 1 Guest are viewing this topic. Read 6070 times.
JM
Speaker parts are sold, but I still have the cabinets stuffed and wired. Available for pick up FREE!
I will dispose of them by Friday, Nov 9, EOD.
I'm in Northern NJ, Montclair area.
_______________________________________ _______________________________________ _
These are the SEAS Thor speakers designed by Joe D'Appolito. SEAS's top-of-the-line loudspeaker kit. A transmission line MTM design. Built in a "fat" cabinet with a volume of about 100 liters for greater bass extension. Crossovers are in separate black aluminum boxes and use high end components: Goertz foil air inductors, Mundorf caps, and high end resistors. Neutral and very detailed presentation with great bass depth and slam.
The cabinet is very well built with extensive bracing (see construction picture) and recessed drivers. Finish consists of 6 coats of shellac primer and 3 coats of white satin paint. It can be easily painted with a different color... There are a few dents in the paint, nothing too obvious, but the cabinets could use a fresh coat.
Feet shown in the pictures are not included. But I will include 2 platforms built for these cabinets that raise the speakers a few inches to clear the down firing port.
Here are the specs for the Thor:
Frequency Range: 40 to 25,000Hz (Gradual low frequency roll off)
Short Term Max Power: 400W
Long Term Max Power: 200W
Crossover Frequency: 2500Hz
Impedance: 4 ohm
Recommended Amplifier: 50 to 400W
Cabinet Type: Transmission Line (Thor)
Dimensions: 45.5" T x 9" W x 14.25" D  (Regular Thor)
Local pick up only for the cabinets. I'm willing to drive up to 50 miles from zip code 07003 to deliver them.
The parts are identical for the Thor kit (transmition line) and Odin MK3 kit (ported). If you're only interested in the parts, I can ship them everywhere.
« Last Edit: 5 Nov 2012, 05:54 pm by JM »
JM
Speaker parts sold like a kit, but I still have the cabinets stuffed and wired. Available for pick up FREE!
I will dispose of them by Friday EOD.
Mike in NJ
Hi I am in Paramus, i can come by and pick them up.
My phone # is 201-952-3847.
Let me know if they are still available.
Mike
JM
Yes, still available!
When would you like to pick them up? Tomorrow?
I'll call you in the AM.
