Audio/Video Gear and Systems
The Vintage Circle
SteveFord
How to test output transformers?
0 Members and 1 Guest are viewing this topic. Read 2057 times.
JohnR
Administrator
testingtesting
8 Oct 2012, 11:33 pm »
I'm going to be selling a stack of OPTs from 50s/60s era amps. Since some are "pulls" from gear that wasn't working, I wonder how to test them. Is a resistance reading through and between all windings adequate? Or is it necessary to use a high voltage supply and ... and what?
SteveFord
Facilitator
Re: How to test output transformers?
9 Oct 2012, 11:52 am »
AVNerdguy says shoot him an email and he'll walk you through it.
JohnR
Administrator
testingtesting
Reply #2 on:
10 Oct 2012, 12:22 am »
SteveFord
Facilitator
Reply #3 on:
10 Oct 2012, 12:25 am »
I'm just the messenger. I guess he figured that would be the easiest way in case you had some unforeseen questions.
Ericus Rex
Reply #4 on:
10 Oct 2012, 12:16 pm »
IIRC, the Morgan Jones Valve amp book has a section regarding testing old trannies to determine specs. Do you have that book?
JohnR
Administrator
testingtesting
Reply #5 on:
10 Oct 2012, 12:43 pm »
Yes I do, and yes indeed there is a section. I will use a variac though instead of direct connection to the mains.
I may also try hooking them into an amp, as I have one I need to work on anyway.
The Vintage Circle
SteveFord
