Newbies- Complete high end systems for under 8k . .
0 Members and 1 Guest are viewing this topic. Read 11874 times.
persisting1
Re: Newbies- Complete high end systems for under 8k . .
« Reply #40 on: 18 Nov 2012, 08:13 am »
Since Anthony Gallo has gone factory direct only, you can buy the Classico IV's for $2500, the TBI Millenia amp is $500, and the great tube AMR Dac is $5000. That totals $8000.
But I could live with the Eximus Dac, $3K, to save $2000 and I hear great things about the $1695 Mytek Dac to save more.
So for less than $5000, the Classico IV's, TBI, and Mytek will be a very hard to beat combo at even spending $8K.
Ozark,
You'd suggest someone spend almost twice as much money on a DAC compared to speakers and amp? Not sure I understand this.
PDR
  • May the best man win
« Reply #41 on: 18 Nov 2012, 09:21 am »
I'm surprised of little more than a passing mention of room treatments...
DIY doesnt seem to garner much attention either....too bad....
8k in DIY system.....wow, at better than 50% mark-up....hitting close to
20k retail.
TONEPUB
« Reply #42 on: 18 Nov 2012, 11:53 am »
Polk Audio LsiM7's  $3000/pair
PrimaLuna Prologue Premium Integrated  $2000.00
Rega DAC $1000
Cable of your choice $1000
Shunyata Hydra 2 $400
Remaining $600 on some basic room treatments from GIK, $600
-$8,000 on the nose
Here's the used/vintage system I just assembled in room two:
Used Krell KSA 50 amp   $1,200
Used CJ PV12 with CJD Teflon cap rebuild  $1,500
Used Acoustat 1+1 speakers $600
Interface rebuild on above  $600
Used Linn LP-12 and Shure V15 mxvr  $800
Various AudioQuest cables $800
Used RSA Haley PLC $600
GIK room treatments $1000
Used Target rack $150
Cheating on digital, as just running a long set of IC's from the dCS in room one,
so no cost there. But could easily live without digital in this system.
$7250
ncblue
« Reply #43 on: 18 Nov 2012, 12:32 pm »
Rega RP6/Exact $2000
Rega Brio-R $900
Oppo BDP-105 $1200
Zu Audio Omen Definitions $3200
Zu cables and GIK room treatment $700
Gives you vinyl, cd, sacd, bluray, dvd and a USB DAC.
Add the Rega DAC later and you're done
doug s.
  • makin' music
« Reply #44 on: 18 Nov 2012, 05:27 pm »
Ozark,
agreed; i cannot imagine spending more than $500 on a dac, regardless of total system cost.
doug s.
doug s.
  • makin' music
« Reply #45 on: 18 Nov 2012, 05:31 pm »
Rega DAC $1000
-$8,000 on the nose
$7250
your first system has zero sources (one if you add something to feed the dac); your second system has no fm...  no fm?  sacrilege!   :green:
doug s.
rjl276
« Reply #46 on: 21 Nov 2012, 06:43 pm »
20k retail.
Agreed. With decades of hindsight, I'd spend at least 2K of an $8K budget getting the room right. One doesn't have to go whole hog to get there. You can 80% of the way by measuring the room and using strategic hanging wall treatments/diffusers. And if you move, you can take a lot of the treatments with you.
