Can all BP-25s be upgraded to BP26?
0 Members and 1 Guest are viewing this topic. Read 1436 times.
dubkarma
  • "God made man because he loves stories." - Canetti
« on: 6 Oct 2012, 06:38 pm »
Hi James,
I'm considering purchasing a used BP-25 for upgrading to BP-26, i.e., I'd purchase the MPS2 power supply and send the preamp itself to Bryston for circuit "adjustments."
 I've done this once already and am happy with the results; that's why I want to do it again for my second system.
My question is: can ALL BP-25 preamps be upgraded to the BP-26 spec? Or are there some early versions of the BP-25 that cannot, or cannot fully, be upgraded?
Or should I simply call Bryston with the relevant serial number(s) to determine whether a given unit is fully upgradable?
Joel Tatelman.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Can all BP-25s be upgraded to BP26?
« Reply #1 on: 6 Oct 2012, 07:01 pm »
Hi James,
Joel Tatelman.
I think all Joel - but check with Mike Pickett.
james\
dubkarma
« Reply #2 on: 6 Oct 2012, 08:06 pm »
Thanks, James; I'll give Mike Pickett a call on Tuesday.
