Adventures into 7DJ8/PCC88 tubes
0 Members and 1 Guest are viewing this topic. Read 1357 times.
WireNut
« on: 5 Oct 2012, 11:26 pm »
Does anyone have any experience with replacing there 6922/6DJ8 tubes in a Linestage preamp with
7DJ8/PCC88 types tubes?
Ericus Rex
Re: Adventures into 7DJ8/PCC88 tubes
« Reply #1 on: 6 Oct 2012, 02:26 pm »
I've tried the Siemens 7DJ8.  A friend told me they wouldn't sound as good as their 6v brethren due to the filament running cooler when in a 6v circuit but I got them anyway (they are usually significantly cheaper than the 6v options so trying them won't break the bank).  I thought they still sounded pretty good.  I can't say if they sounded less good than the 6v option as I didn't have the 6DJ8 from the same brand and time period to directly compare them to.  Hope this helps!
