FS: Top of the line Symphonia 7R macassar ebony hand rubbed piano finish
0 Members and 1 Guest are viewing this topic. Read 2562 times.
Jed
    • Clearwave Loudspeaker Design
Picture a speaker that disappears in your listening room and creates a depth of sound stage like no other, and you will find the Symphonia 7R. Contained within the rigid, non-resonant, and diffraction optimized bass reflex enclosure, resides a lightning fast and custom developed ribbon tweeter with amorphous core transformer for the most micro-detail possible. The ceramic seven inch woofer with mechanical resonance control dots is the perfect partner.
The completely hand assembled point-to-point crossover blends these drivers together with a transition that is so pure, only the music comes through, and no details are left unresolved in your music collection. Only the fusion of art and science can make this possible after years of trial and error with one goal in mind; the ultimate stand mounted 2-way loudspeaker.
The Symphonia 7R monitor has all the attributes of his larger brother but in a smaller package. They will fit the needs of the audiophile who has a smaller room or someone who doesn't need the higher sensitivity and dynamics which dual ceramic woofers provide in the 72R.
Please note the picture used here is the Symphonia 7R with optional Macassar Ebony and piano finish. The standard finish is a silky satin along with domestic veneers. They start at only $4695.00.
Coming next..... Symphonia 7R and 72R in waterfall bubinga.  I can't wait.  Lets build yours next!  Our turn around times are very reasonable for the quality offered to our clients.
Best Regards,
Jed
www.clearwavespeakers.com
« Last Edit: 25 Oct 2012, 12:11 am by Jed »
Jed
I forgot to list a few features included in the low price (standard equipment):
RAAL Amorphous Core (OEM only) tweeter built to our specifications with non resonant aluminum custom faceplate
Clarity Cap MR in signal path-- all poly crossover and heavy air core inductors from ERSE
Accuton 7" midbass with resonance control
2" thick baffle and multiple bracing makes for a cabinet built like a tank
5 degree slant back to align acoustic centers of drivers
Custom aluminum trim and binding post plate with copper Cardas binding posts
Tube amplifier friendly
Minimalistic crossover design yet flat impedance that doesn't vary more than a couple ohms from 100hz on up
Flat frequency response on and off axis... graphs emailed on request
We're very proud of this design.  It has gone through years of refinement, panels of listeners, and many iterations to become what we have now.
Thanks for your interest!
Jed
Jed
We have a set of 1st generation 7Rs done in mahogany if anyone is interested.  They're currently over in the shop at Long Island.
Jed
New 7R and 72Rs in Waterfall Bubinga will be available soon.  This is some gorgeous veneer.  Email me for more info.
