2SA1142 PNP Transistor or equivalent?
0 Members and 1 Guest are viewing this topic. Read 2283 times.
andyr
« on: 2 Oct 2012, 09:36 pm »
I am trying to source some 2SA1142 PNP transistors. Can anyone suggest either:
* a good source of supply, or
* an equivalent device?
I was told this is a higher-wattage equivalent of the BC560C but doing a search on Mouser and RS Components comes up blank (so maybe I wrote the number down wrong)?
Andy
stvnharr
Re: 2SA1142 PNP Transistor or equivalent?
« Reply #1 on: 5 Oct 2012, 03:07 am »
Andy,
Try KSA1142, which is quite common. However this is in a TO-126 package, not a TO-92 package like the BC 560.
G Georgopoulos
« Reply #2 on: 5 Oct 2012, 03:14 am »
Andy
You could try wagner elecronics at  http://wagner.net.au/
andyr
« Reply #3 on: 5 Oct 2012, 09:27 am »
Thanks, GG.  Wagner is the retail arm of the wholesale WES supply group.  I was directed to them by someone on DIYAudio ... and I ordered 40.  :)
Andy
andyr
« Reply #4 on: 5 Oct 2012, 09:29 am »
Andy,
Thanks, Steven,
I searched that code at several suppliers but didn't find anything.  But as I posted above, I was directed to WES, who had some 2SA1142s in stock (TO-126 package).  :)
Andy
