Seeking quality high-value solder iron
0 Members and 1 Guest are viewing this topic. Read 3465 times.
James Romeyn
« on: 2 Oct 2012, 08:19 pm »
Thinking <$75.  What should I consider?
*Scotty*
« Last Edit: 2 Oct 2012, 09:54 pm by *Scotty* »
Berndt
Re: Seeking quality high-value solder iron
« Reply #2 on: 2 Oct 2012, 08:50 pm »
Jimbo, this is the one I've been running the last few years, after using it Edwin got one too.
 http://www.amazon.com/gp/aw/d/B000BRC2XU
wushuliu
« Reply #3 on: 2 Oct 2012, 09:25 pm »
Recently purchased the Hakko and now kick myself for having waited so long to buy one. Hits the desired temp in seconds, well built, easy to use.
SET Man
« Reply #4 on: 2 Oct 2012, 09:27 pm »
Hey!
   I've been using Weller WLC100 for couple of years now. Not as precise as the more expensive one but it is good enough for most works with it 40 watts.
   You can get one for $45 or less. But if you got more budget a Hakko will be a better... I might get one someday.
Take care,
Buddy :thumb:
*Scotty*
« Reply #5 on: 2 Oct 2012, 09:35 pm »
Here is a link to the technical information on the Hakko FX-888.
http://www.hakko.com/english/products/hakko_fx888.html
Scotty
rajacat
  • Washington State
« Reply #6 on: 2 Oct 2012, 09:40 pm »
Hakko FX-888. 80 bucks.....not too much over your specified $75 for definitely the best in it's class. :thumb:
http://www.tequipment.net/HakkoFX888.html
jcotner
« Reply #7 on: 2 Oct 2012, 10:10 pm »
Kind of a second on the Weller. I've been using the WES50 for a long time
and I've done my share of serface mount work with it.
Don't know the difference between the 50 and 51 but would imagine they
are very much the same iron.
bwaslo
    • Liberty Instruments
« Reply #8 on: 7 Oct 2012, 02:43 am »
+1 on the Hakko.  Best iron I've worked with, other than the Metcal (which starts around $500).
Delta Wave
« Reply #9 on: 7 Oct 2012, 03:14 am »
+2 on the Hakko... the iron is better and the base/holder is far better.
rafjr00
« Reply #10 on: 12 Oct 2012, 02:47 pm »
If you want to save a few bucks just keep your eye out for a good used Hakko 936.
Unison845
« Reply #11 on: 16 Oct 2012, 05:26 am »
The absolute best is Metcal, found one at the DeAnza college swap meet for under $100.
G Georgopoulos
« Reply #12 on: 16 Oct 2012, 05:49 am »
Make sure it comes with alot of tips,tips fail over time,hope this helps...
cheap-Jack
Hi.
Sota O.T.
Don't put the cart before the horse, my friends.
Solder iron is to melt down the solder to make proper electrical joints. In fact, quality solder which makes or breaks a 100% perfect electrical joint, is the crucial 'tool' we should spend money on.
Good solder do NOT need expensive solder irons. You may call me "cheap" again as I never spend over $10 bucks for a solder iron for building successfully tube phonostages, tube power amps & 4N pure silver ICs & power cords.
I just picked up a basic 30W iron as a backup from a neighbourhood Harbor Frieght Tools store when I was enroute my vacation trip at St Jose for only USD3.50 on sale.  Too good a deal as not to buy one.
How come? Save the money on expensive irons for quality solder wires. That's what I've been doing since day one of my DIY. Get silver solder wires!!!!! No lead solder which is toxic & needs expensive hi-watt solder to struggle with.
To be honest, my silver solder wires are not expensive at all. It is always - MG chemicals lead free silver solder wire (packed in a long plastic tube, net weight  0.6oz) - 96.5% tin, 0.5% copper & 3% silver. A 0.6oz tube only costs me $3.50 from a local electrioncs store! It works like a chime using a basic cheapie iron, enviromentally GREEN. :thumb:
For those who want to cool down the iron a bit while idling, add a sand diode in series of the AC mains to drop down half the power supply to the iron.  Why have to spend big bucks to acquire a thermal-control solderng station which works on the same voltage-drop principle.
Be a smart consumer!
c-J
