WTC Protractor Revisit — HELP!!!
0 Members and 1 Guest are viewing this topic. Read 3270 times.
jsawyer09
« on: 2 Oct 2012, 04:52 pm »
Hi all.
Okay, so after scouring the ENTIRE web, along with this forum (to some incredulity, I might add...cannot believe after all of the inquiries that nobody has supplied an online version of this), I'm going to go for a shot in the dark and ask if anyone could send me a pdf of the Well Tempered Classic/Reference alignment protractor.
I see that it is close to Stevenson, but alas, no cigar, as the WTC arm is approximately a couple of mm short on the inner null in comparison with regard to cartridge aligmnent; just about right on the outer, though.  :duh:
I cannot tell you how appreciative I'd be if someone...anyone could help me out. Cheers!
doak
Re: WTC Protractor Revisit — HELP!!!
« Reply #1 on: 4 Oct 2012, 03:49 am »
For jsawyer09: PM sent.
jsawyer09
« Reply #2 on: 4 Oct 2012, 08:56 pm »
A BIG THANKS goes out to Doak and Mike Pranka.
Member Doak has sent me a pdf, so all's well with the world...at least for now.
One of the leads on the Classic arm snapped last night, so now I need to have the tonearm re-wired. Investigating what I should do or send it to... :duh:
Thanks again!!!
mgsboedmisodpc2
« Reply #3 on: 4 Oct 2012, 10:55 pm »
"tonearm re-wired"
I pulled out one of the clips from one of the wires an simply soldered it back on which may be an option for you
jsawyer09
« Reply #4 on: 5 Oct 2012, 01:45 am »
mgsboedmisodpc2,
I sent you a pm. Very interested to hear about soldering the wire back.
threadkiller
« Reply #5 on: 5 Oct 2012, 04:14 am »
I did the same once.  If I can do it anyone can.
davaughn
« Reply #6 on: 22 Oct 2012, 08:50 pm »
I would love to get a copy of that PDF if possible. Thanks!
jsawyer09
« Reply #7 on: 24 Oct 2012, 06:06 pm »
davaughn: PM sent.
12ax7
« Reply #8 on: 2 Mar 2014, 10:09 pm »
I am hoping to get a copy of the pdf for the Well Tempered Classic that I just bought. I am watching it spin but I don't want to paly anything on it until I know it is setup correctly.
