0 Members and 1 Guest are viewing this topic. Read 12382 times.
No tubes other than in the preamp.Gear: Mog- Apple TV- optical- Peachtree Nova Pre- Peachtree 220- Gallo 3.1s (no balance control) Room: 10' L 9' W Im sitting on the 9' wall, I cant position anything the other way around. Ceilings are 8' if im not mistaken.
switch tubes left to right and see if it swings the other way
Good advice, but is is noted that the OP states he tried another preamp. How hard would it be to swap the left for right cables one set at a time to rule them out ?
Can you move your speakers back to where they were to put all theories to the test?
Swap only the two speakers before you return everything to the past configuration. It'll be interesting. Edit: It is noted that you previously changed out speakers . I'd follow rockadanny's advice and put everything back the way it was.
Could it be that your left speaker is a couple of inches closer to the listening position than the right speaker? If one speaker is closer to you, your brain will perceive it as louder and your center image will shift. Get the tape measure out and check.
