0 Members and 1 Guest are viewing this topic. Read 51092 times.
Ok... My Nak's are on order. Whether I attach them with Wayner's method of increasing the diameter/surface area of the wire by back twisting it which is a great idea! Or I use one of the other mentioned methods I will need to decide on what wire to use?? I know this has been discussed to death previously, but I am totally new to this, and would appreciate any "cheap & cheerful" suggestions you guys have. I am building my C&C system from scratch. All I really am looking for is one good proven cable and whether it should be twisted, braided, two into one, etc. It doesn't matter if it's cat 5/6, Blue Jeans bulk Belden cable, etc. I just want something that will be acceptable, and be cheap and cheerful, <$1.00 foot and work with the Nak'sThoughts appreciated...Larry
RE: Nakamichi BFA Speaker banana plug connector 24k Gold plated 0534E - - http://www.nakamichiplug.com/product-0534E12.html purchased directly from Nakamichiplug.com, not from ebay.Does 12 AWG fit into these plugs? I would think that if 16 AWG (1.291 mm diameter) doubled over fits, 14 AWG (1.628 mm) or 12 AWG (2.053 mm) should fit. I could always heat shrink over the screw if it stuck out a bit.TIA!
