CD 30 years old
0 Members and 1 Guest are viewing this topic. Read 9498 times.
plaf26
CD 30 years old
« on: 1 Oct 2012, 04:59 am »
Interesting retrospective on CD sound at http://www.kenrockwell.com/audio/sony/1982.htm
Rclark
Re: CD 30 years old
« Reply #1 on: 1 Oct 2012, 05:14 am »
I love cd. Long live the cd.
Rclark
Re: CD 30 years old
« Reply #2 on: 1 Oct 2012, 05:20 am »
 For those who won't click, it's an excellent article:
"30 Years of Perfect Sound Forever
Eagerly anticipated since the digital audio revolution in recording studios in the late 1970s, Sony announced the CDP-101, the world's first Compact Disc player, on October 1st, 1982.
The Compact Disc was developed in concert by Sony, who handled the DSP, and by Philips, who had experience with optical discs.
Sony and Philips each owned large record companies as well as electronics divisions, so they had everything to gain. Other record companies hoped it would all go away, wanting us to pay money for more of the same old LPs instead of new CD players and having to dual-inventory recordings.
Philips dubbed the Compact Disc as "Perfect Sound Forever," and they weren't kidding. My 30-year-old CDs still sound incredible, and lost to history after video replaced music in the late 1980s for most people's home entertainment is that CDs still offer the best possible sound today, still representing a completely transparent window to the original recording.
CDs as a recording medium are completely uncompressed, unadulterated and bit-for-bit accurate, even if you boil them or drill a hole through them.
Any flaws, like with any medium, are because people rarely record well enough to them to use all the range of which CD is capable. If aa CD doesn't sound fantastic, that's because you've got a flawed recording, not a flawed medium. It's no better than whatever sound people choose to put on it. As a medium, the 16-bit 44.1 ksps (kilo-samples per second) CD is capable of more dynamic range than music itself, as I'll explain.
While professional editing, mixing, processing, equalizing and level shifting usually use more data bits for computation (24 bits linear, 32-bit floating point or now 48-bit linear), 16 bits is more than enough for unlimited fidelity as a release format.
The reason we use more bits in production is so we can create and preserve a true 16 bits through the whole process after all the truncation and rounding and nastier stuff that goes on between the microphone and your CD.
16 bits is more than enough, and with popular music today, even 8 bits is more than enough.
How is this?
16 bits have a signal to noise ratio of 98 dB (theoretical SNR = (bits x 6.0206) + 1.72 dB). That doesn't sound like much compared to 24 bits theoretical 146 dB, but realize that a library's background noise is about 35 dB SPL. Your house probably isn't any quieter. A full symphony orchestra giving it all it's got (ƒƒƒƒ) peaks at about 104 dB SPL. Let's give the orchestra 105 dB, and 105 dB - 35 dB = only 70 dB real dynamic range if you brought the orchestra into your home.
Even though some people can hear to 0 dB SPL, we're always hearing background noise if we shut up and listen. It takes a lot of money to build an NC 25 or NC 15 studio, in other words, a recording studio with about a 15 dB or 25 dB SPL background noise. Even in an NC 15 studio, 105 - 15 = 90 dB SPL, well within the range of real 16-bit systems, if you record it well.
Supposing we recorded on the moon in a pressurized tent with no background noise? Well, the self-noise of most recording studio microphones is about 16 dB SPL equivalent input noise, or in other words, microphones aren't any quieter than about 16 dB SPL anyway.
16 bits was chosen because it has more than enough range to hold all music. I know; I was doing 16-bit recording back in 1981 before the CD came out, and my recordings would have their levels carefully set so the loudest peak of the entire concert hit about -3 dB FS, and leaving it running after the audience left and the hall was empty, you can still bring up the playback gain and hear a perfectly silent recording of the air conditioning noise in the hall. The world just doesn't get quiet or loud enough to need more than 16 bits as a release format, if it's recorded well.
There is no such thing as a real 24-bit audio DAC or ADC. Look at the specs, and you'll never see a 144 dB SNR spec; all audio 24-bit converters do have 24 bits wiggling, but the least few LSBs are just noise. There is plenty of 24-bit and higher DSP, which is good to keep the 16-bits we need clean, but you're never getting 24 real bits of analog audio in or out of the system. It's a good thing you can't; 140 dB SPL is the threshold of instant deafness, and if you lift the gain enough to hear a real 24-bit noise floor at say 20 dB SPL in a very quiet studio, maximum output would be 20 + 144 = 164 dB SPL, or 4 dB over the threshold of death. Yes, 160 dB SPL kills.
But wait, there's more. 98 dB is the theoretical SNR. With dither, we still can hear pure undistorted signals down into the noise for at least another 10 or 20 dB. While a typical real-world 16-bit system's SNR might be 92 dB, we can hear tones down to -100 dB FS easily. That's over 100 dB of dynamic range in real 16-bit systems.
There's even more than that! By the 1990s, people learned how to "noise shape" the dither to push it up mostly to 15 kHz and above, so it became much less audible, but just as effective as regular dither. These systems made the noise much less audible. These systems are also called Super Bit Mapping (SBM) by Sony and UV22 by Apogee; they claimed 22-bit effective SNRs with 16-bit systems. They didn't really work that well, but they did make our 16-bit system even better than it was. These clever sorts of dither are still used today for 16-bit releases.
That's right: done right, 16 bits is way, way more than enough for any sort of music. Once you've heard it done right, you'll realize any noise you here out of a CD is due to sloppy recordings (usually sloppy level settings someplace in the chain), not the CD medium itself. GIGO as you computer guys say.
When the CD came out, it was like something from another planet. No one outside the recording industry had ever heard completely silent undistorted recordings. LPs had not only clicks, pops and scratches, but they also were usually loaded with distortion (we used to tape our new LPs so they wouldn't get worse), they were rarely pressed on-center so the pitch varied as the disc rotated, and warps made our woofers flutter like crazy. LPs were nasty, compared to pure live music. In radio, "cue burn" was the first few seconds of grunge you'd get from back-cueing the same record 100 times to find its start.
in 1982, no one except computer nerds had computers. It wasn't until the late 1980s that hard drives were seen commonly, and then they were only 10 megabytes, an astounding number. By 1985, computers still only used 5-1/2" floppies, which held only 720 kilobytes if you had the HD ones. Microfloppies, the 3.5" kind, were crazy stuff when Apple first used them on a computer in 1987. They were small, tough, and held an amazing 1.44 megabytes. Even until about 1992, only engineers had computers at work.
The CD in 1982? It held an unfathomable 650 Megabytes, or as much as 65 hard drives would be able to hold three years in the future! Even in 1985, no one could afford a 10 MB hard drive. I worked in defense in 1985, and we did our calculations on computers with dual 5.5" floppies; no hard drive. That's why hard drives are called the C: drive; the A: and B: drives are your two floppies: one for the program, one for your data.
Anyway, CDs were always laser rocket science. It wasn't until about the year 2000 that anyone could afford a CD burner.
Some people forget today that the CD is a 100% bit-accurate medium. It puts the same data on the disc in multiple places, and using various kinds of error correction and detection and eight-to-fourteen modulation, so no matter what happens, you get everything back exactly as it was recorded. You can even drill a small hole in an CD, and the data will be recalled with 100% accuracy, since the CD player simply pulls the data from different sectors.
Today, there is still nothing better, and nothing even as tough.
The SACD was a marketing ploy around 2002, but it's huge problem is that SACD puts out a ton of ultrasonic hash (noise) even when it's working perfectly. SACD player instruction manuals warn not to crank the levels during silence, because this ultrasonic noise might blow your tweeters! CD players haven't needed sharp 20 kHz anti-alais filters for decades, but SACD players need them today!
Here's an anecdote about how bad is the noise out of a good SACD player. I was playing around dubbing to cassettes, and something sounded horrible, as if the tape was all twisted and garbled with Dolby, even Dolby B. A little red light went on in the back of my head, and I said "No, it couldn't be this bad," and hit the multiplex filter on the cassette deck. That cured it. In all my years as an FM radio station chief engineer, I never found any FM tuner so bad that it didn't filter the 19 kc pilot well enough to need the MPX filter. Never. But welcome the SACD, and lo and behold, its output is laced with so much ultrasonic crap that I needed the MPX filter to get Dolby to track. Horrendous! My iPod is much cleaner (and pretty darn clean, too)!
But what about people today sharing files and pumping them into fancy outboard DACs from their computers? That can work great, but there are a few reasons why a good CD player can be better than a great outboard DAC:
1.) Jitter. A CD player has no measurable jitter. Data is read and corrected from the disc, and the data fed to a first-in, first-out buffer. Data is clocked out of the FIFO into the player's own DAC at the exact rate of the quartz-crystal oscillator of the CD player. The disc's rotational velocity is varied in a closed-loop to feed the FIFO exactly what it needs, all controlled by the player's one low-phase-noise and low-jitter quartz crystal oscillator. The only jitter is the residual of the quartz oscillator, which actually has less phase noise (jitter) than an atomic standard!
When you use an outboard DAC, unless you're a professional and have a Word Clock or other separate Sync output fed to your DAC for the clock signal, the DAC has to guess at reconstructing the clock signal from the audio data it's fed via TOSLINK or USB or RCA or AES. (those interfaces carry only data, not clock.) Noise added to the natural high-frequency attenuation in any length of cable adds jitter to the recovered clock, and as my own tests have actually shown, there is a measurable increase in measured jitter actually seen on the analog outputs of outboard DACs versus direct from a one-box CD player. This tiny amount of jitter isn't significant, but seeing how there is a cult of whackos who worry about things that are far less significant, the fact that I can measure and show jitter picked up in a top-notch DAC at its analog output under very good conditions impresses even me.
2.) Ground Loops. If you use an outboard DAC, use the optical TOSLINK connection. If you don't and you take a digital input from a computer via USB, Firewire, RCA or any other wire, you're now coupling any ground noise from your computer's digital circuits into your audio ground.
As a guy who used to design ADCs, DACs and DSP systems, we do everything we can to keep the digital hash out of the analog circuitry. Never, ever connect the two grounds together at any more than one point, and that one point will probably be your power outlet at the wall. Don't go using USB or similar and connect your computer's ground to your audio system!
3.) Noise. Most computers have fans or hard drives that make audible noise. Most CD players spin silently.
4.) Overload Handling. This is a potentially really nasty one that needs more research. In the beginning, CDs were cut with 0 VU at -20 dB FS, in other words, there was plenty of headroom. The world's first released CD, Billy Joel's 52nd Street, never even hits full scale, and it sounds great.
Once everyone had a CD player in the 1990s, some bonehead got the dumb idea that if he made his CD sound louder than the next guy, that people would like the music better. Dumb idea, yes, but as of today, most popular CDs have so much dynamic compression applied that they sound as bad as radio: one big long 100% modulation wall of boring. Jazz, classical and a very few acts like Peter Gabriel's latest still use all the dynamic range, but just about everything else today is squashed to death to put everything at 100% loud. Today, most CDs only use the top couple of bits!
Worse, CD mastering continues to get worse in its attempts to get louder, and many CDs use another radio trick, composite clipping. Yes, the waveform is boosted even more and the peaks of the waveform are clipped, and since most people won't know, helps squeeze another dB or two of level onto the CD.
Today, some albums have levels when measured with a Tektronix 764 that exceed 0 dB FS! How do they do this? Well, levels are calibrated to read 0 dB FS for a sine wave, but when a proper meter like the 764 is used that properly reconstructs the actual audio waveform digitally as opposed to simply looking at data stream values, clipped signals approximate square waves, and approach +3 dB FS!
This is all fine and dandy played on a CD player, which simply reproduces the music, clipping and all, as recorded.
It can wreak Hell when you start ripping that to AAC for your iPod, or play it on an external DAC, most of which aren't designed to have enough headroom to reproduce the crazy transients that are there with 100% clipped signals. Most audio DSP norms were created back before producers started putting such nasty signals on music CDs.
As my CD player and outboard DAC tests have shown, weird things happen when playing extreme square wave tests. Outboard DACs for whatever reason often lack the headroom in their DSP for this baloney, and someone needs to do more research to see what happens with real, loud, CDs when attempting to reproduce them over an outboard DAC. Look at the spectrum of a square wave played by a good CD player and that same disc played with a great outboard DAC. You should only see odd harmonics; the even harmonics from the outboard DAC are from clipped transients. (PS: I point to the Benchmark DAC1 HDR simply because it's the world's best outboard DAC; you don't want to see what lesser DACs do to these signals.)
I was totally excited when the CD came out and for the first time in my life I could get essentially direct copies of the master tapes just by buying a CD, and that those CDs still sound perfect 30 years later. In fact, my old CDs usually sound better than newer ones, which are all squashed to death by today's remasters.
You folks might also be tickled to know that most recordings are made with vacuum-tube powered microphones today plugged into vacuum-tube preamps before they're digitized and fed into ProTools software. Tubes rule in the world of pro sound.
If you don't like what's coming out of your CD player, try a better CD recording. The CD itself is incredible, but few recordings really show you what it can do. Blame the producers who think we're too stupid to turn up the volume on our iPods if they actually used some dynamic range.
Today's moral? Buy more CDs, put them on your iPod and computer if you like, and enjoy them. Get a great DAC if you've got computer stuff to enjoy, but don't waste your time futzing with computer equipment and music software when you can just buy CDs and enjoy the music itself instead of fiddling with stereo gear. God help us that some people waste time fiddling on their computers just to get music; half the reason the general public loves the CD over LP is simple convenience and never having to align a cartridge, flip an album or clean records or worry about wearing them out."
cheap-Jack
Re: CD 30 years old
« Reply #3 on: 1 Oct 2012, 05:26 am »
Hi.
Grammophone disc (circa 1920s) is now over 90 years old & still kicking around. I love it bigtime.
c-J
PS: I still play CD-audio & DVD-audio though I prefer stereo LPs better.
Rclark
Re: CD 30 years old
« Reply #4 on: 2 Oct 2012, 03:33 am »
 That was an incredible article on many levels, I almost want to repost it where it will be seen more. Thanks for posting that, sure confirms that I don't need to change anything right now. I love having a cd collection too, and add to it weekly.
cheap-Jack
Re: CD 30 years old
« Reply #5 on: 2 Oct 2012, 07:12 am »
Hi.
How "incredible" it might be as you claimed it. The author of yr link on that article did not appear to me he ever owned or lived with DVD-audio/SACD for a reasonable time let alone vinyls. One sided opinion, buddie.
c-J
satfrat
Re: CD 30 years old
« Reply #6 on: 2 Oct 2012, 07:59 am »
Hi.
c-J
As one sided of an opinion as yours seems to be evidently.  :lol:
Re: CD 30 years old
« Reply #7 on: 2 Oct 2012, 09:13 am »
Happy birthday CD!
Still love the technology and it's spin offs (DVD/Blu-Ray).  So much better than vinyl surface noise (finger nails on chaulkboard to me).  So convenient (computers are too convenient, I need to get off my butt every so often).  And I have no compliants of the sound (again it boils down to the quality of the recording).
Those who disagree are either vintage hounds or itch for the latest (greatest?) toys.  Wish more manufacturers would be satisfied still making CDPs (yeah Oppo).
JMO
Rclark
Re: CD 30 years old
« Reply #8 on: 2 Oct 2012, 04:40 pm »
Me too!
And by incredible I was referring to all the facts about cd sound that I never knew. I have made a lot of great choices for my system so far and I believe doubling down on cd's instead of switching (back) to computer has been a serendipitous one.
 I used to have an all computer based, mp3, WAV collection, PC speaker, Senn headphone, but switched entirely to cd several years ago, it was the first small step I took on this system build journey.
The well recorded cd material sounds just as good as good audio tracks on my blurays.
Quiet Earth
Re: CD 30 years old
« Reply #9 on: 2 Oct 2012, 05:48 pm »
I liked the article.
I get a lot of enjoyment from CD now, and I hope to get another 30 years.  :thumb:
SET Man
Re: CD 30 years old
« Reply #10 on: 2 Oct 2012, 06:21 pm »
Hey!
   Ken Rockwell is now an audio writer/reviewer too? Really?  :lol:
Take care,
Buddy :thumb:
simoon
Re: CD 30 years old
« Reply #11 on: 2 Oct 2012, 06:36 pm »
Even though it took a while for CD's to actually become listenable to me (probably about the late 90's), it is a great technology. I am so reluctant to go hi-res music server because I just love having physical media.
I worked at a high end store in Los Angeles (Audio Research, Magneplanar, Eagle, Sota, VTL, Sumo, etc) when they were first released, and let me tell you, those early CD players, even the best ones, were horrible. Far from 'Perfect Sound'.
As far as the never ending 'CD vs vinyl' debate, CD's do MOST things better than vinyl, but not everything. I wish those 'vinyl sucks' people out there could understand this.
rajacat
  • Washington State
Re: CD 30 years old
« Reply #12 on: 2 Oct 2012, 08:06 pm »
CD's will probably be obsolete in the not too distant future. Music will be downloaded and the CD player will join cassette and 8 track players in the dustbin of history. Vinyl will always be here because it's true analogue and it has a very hardcore group of fanatics :).
Quiet Earth
Re: CD 30 years old
« Reply #13 on: 2 Oct 2012, 08:42 pm »
Be careful what you wish for..... you might just get it in the form of mp3 singles.
I never understood why we weren't allowed to like both formats. I like tape too.
Wayner
Re: CD 30 years old
« Reply #14 on: 2 Oct 2012, 09:11 pm »
In the past 30 years, recording technology (mics, digital recorders, automated mixers, computer audio recording) has improved tremendously and may be some of the reasons new recordings sound so good. Also remember that DAC chip sets have come along way, as has the filtering. The good news is that this benefits all the music formats (including vinyl, hi-rez) and takes listening to the next level. I guess you could say it's a technology, evolving inside of another technology and so on.
Wayner
Rclark
Re: CD 30 years old
« Reply #15 on: 2 Oct 2012, 09:21 pm »
 I'm just gonna keep buying cd's while the getting is good. I'm past the point of no return on vinyl.
Rclark
Re: CD 30 years old
« Reply #16 on: 2 Oct 2012, 09:24 pm »
 I love having the physical media too, and all that comes with it, the artwork, booklets, bio's, posters, photo's, band notes, wierd quirky stuff, tickets, discount coupons.
 shoot I'm gonna go to the record store right now.
kevin360
  • án sǫngr ek svelta
Re: CD 30 years old
« Reply #17 on: 2 Oct 2012, 09:43 pm »
I have some CDs from '82 and they still play perfectly. Not only that, but the first player I bought (also from '82) still works. I pull it out of the closet every year or so and give it a whirl. Of course, it was built like a tank. Remember these?
In fact, I've purchased over a couple thousand CDs and have only had a problem with one - pretty amazing.
dB Cooper
Re: CD 30 years old
« Reply #18 on: 2 Oct 2012, 10:44 pm »
I gotta figure out how to do multiple quotes- wanted to respond to both rajacat and Quiet Earth.
I saw a report a year or so ago that said that 30% of music titles released that year (2009 or 2010) were released as digital downloads only- there was no release in any physical format at all. It is probably a reasonable assumption that this is a number that will only increase. Hopefully sources like HDTracks will thrive, because if the only source material option is lossy compressed formats, what reason is there for there to be a "high end" ?
Oh, and Kevin360- Yes, I remember those players (with their 14-bit processors). My next door neighbor had one. Underwhelmed at the time (the highs sounded very "hard" to me) but as the players evolved, they became much more listenable.
medium jim
Re: CD 30 years old
« Reply #19 on: 3 Oct 2012, 03:52 am »
The 16 bit 44.1 technology is more than sufficient as it can record the full spectrum and with almost a dead black background or sound floor.  The mastering is paramount and it is just that that gives the illusion that hi rez is superior.  I have two cdp's, a highly modified Marantz who's power supply was completely redone and has two E188CC tubes.  The other is a Rotel that actually is a bit warmer, go figure.
The main issue with CD's is that they are recorded compressed as opposed to raw uncompressed that allows all if the dynamic sweeps and nuances to come through.  Most sacd's are remastered uncompressed and this us why they sound better as a general rule.
Thank goodness that most if the music I listen to were recorded uncompressed.  I think the decibel war days are over and most current CD's and downloads are now uncompressed.
It is hard to believe it has been 30 years.  IMHO, CD's will never die and will always be there.
Jim
