surrounds
0 Members and 1 Guest are viewing this topic. Read 2138 times.
ratso
surrounds
« on: 28 Sep 2012, 07:30 pm »
i have been kicking around new surrounds (7.1) for quite some time now. selah has a whole range of monitors that would work, i have been eyeing the SSR's for instance. all of them seem capable of easily crossing over to a sub. i am looking at sealed cabinets for easy placement. the question is, are the SSR's overkill for monitors? should i start my search lower in the line? higher? these aren't going to be used as mains remember, just surround duties. where would a good entrance point be in the line up for a high quality surround speaker? specifics: i have salk HT2-TL's as mains and dual rythmik subs. my eventual HT space will probably be arround 7'H, 15W, 21D. i listen to more music than HT including 5.1 DVD-A and SACD.
Marbles
Re: surrounds
« Reply #1 on: 28 Sep 2012, 07:50 pm »
I have Salk ht3's/htc up front, and have Selah Tanzanites for surrounds, and Selah custom in wall Tanzanites, although Rick might have another name for them. I also have Rythmik subs.
I have not heard the SSR, but based on what I have heard, see no reason they wouldn't work great.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: surrounds
« Reply #2 on: 28 Sep 2012, 09:32 pm »
Since you listen quite often to music in surround it's more common to have a speaker that is similar in tonality to the front L/C/R. In this case the S6 is what I would suggest. It's more compact than the SSR and the woofer is a better match for your mains. Here's the link to it...http://www.selahaudio.com/id170.html
ratso
Re: surrounds
« Reply #3 on: 28 Sep 2012, 10:16 pm »
thanx to you both, esp. you, rick!  :thumb:
