upgrading a fet valve 400r to 600r?
0 Members and 1 Guest are viewing this topic. Read 1864 times.
guf
« on: 28 Sep 2012, 05:43 am »
 the more i refine my system, my room, and my sources i find i can easily and enjoyably listen at louder levels. so i am. i think i read the upgrade would be the difference in price. it's 500$. it worth it? will i even notice a difference? my speakers are ht2-tl.
thoughts?
avahifi
    • http://www.avahifi.com
Re: upgrading a fet valve 400r to 600r?
« Reply #1 on: 28 Sep 2012, 06:05 pm »
Well, you will jump from 200W/Ch to 300W/Ch with no negatives at all so its a really good deal if you can afford the $500 upgrade cost.
Frank Van Alstine
Austin08
« Reply #2 on: 28 Sep 2012, 06:19 pm »
$500 for 100 more watts with totally same sound characteristic which you like is dam dirt cheap. Go for it.
Kwebb
« Reply #3 on: 30 Sep 2012, 04:05 am »
I have the 600R and absolutely love it.  Can't go wrong with the 600R.
Kyle
