Variable output stage headphone amps
0 Members and 1 Guest are viewing this topic. Read 1586 times.
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« on: 28 Sep 2012, 02:25 am »
What are your thoughts on this folks? it seems like hi-fi companies are using this more often:
http://bursonaudio.com/More_VOS.html
« Last Edit: 28 Sep 2012, 03:32 am by Noseyears »
dB Cooper
Re: Variable output stage headphone amps
« Reply #1 on: 28 Sep 2012, 02:53 am »
If Burson wants to send me one, I will let them know what I think.  :roll:
JohnR
« Reply #2 on: 28 Sep 2012, 02:55 am »
Hang on. That has nothing to do with the output stage, it's just a selectable gain switch  :scratch:
Noseyears
  • SS-Audio
« Reply #3 on: 28 Sep 2012, 02:59 am »
Do you think the idea its similar to this one:
http://gilmore2.chem.northwestern.edu/projects/showfile.php?file=simpson_prj.htm
JohnR
« Reply #4 on: 28 Sep 2012, 03:09 am »
From the brief description (on the Burson page) it looks the same thing. As with any other amp with a selectable gain switch, like the O2 and presumably countless others. The description "The new VOS provides 3 level of gain to the preamp function from 7db to 18db" doesn't indicate there's anything more to it than that.
Noseyears
  • SS-Audio
« Reply #5 on: 28 Sep 2012, 03:55 am »
Alright, from my understanding (im not expert on electronics, know some basics only)
It depends on the design, for example. A)It can be a true gain switch, and it adjusts the amplification level of the circuit
B)Is just a potential divider to cut the signal level.
C)An output impedance selector, which by default will deliver differing signal amplitudes according to setting.
G Georgopoulos
« Reply #6 on: 28 Sep 2012, 05:23 am »
You're right about A and B, I don't have a clue about C though.
Cheers :)
JohnR
« Reply #7 on: 28 Sep 2012, 08:33 am »
I also am not sure what C means, but I don't think it's a candidate anyway as Burson specifically say it's in the preamp section.
