New A/V-3 versus Original A/V-3
0 Members and 1 Guest are viewing this topic. Read 1838 times.
jjb
« on: 9 Jun 2004, 01:58 am »
Danny, I purchased and built your original a/v-3 design just after you introduced the line, a year later I upgraded with the sonocaps, I like the smaller footprint of the new A/V-3 and realize the new bass/mid range. Would I experience a significant improvement with the new model ?
Happy GR Customer since 1999
Danny Richie
    • http://www.gr-research.com
Old verses new.
« Reply #1 on: 9 Jun 2004, 10:26 pm »
There are improvements in some areas.
Bass response is better controlled, tighter and faster. Midrange has some added detail but may give up a little fullness.
The very bottom end was a little stronger in the older version that used the larger woofers.
The really good thing about the new one is that it has a small sealed box matching center.
Plus, it is a smaller size and in more narrow (higher WAF).
No really big performance improvements though, same basic character and sound.
