Bryston gear and the (missing) display
0 Members and 1 Guest are viewing this topic. Read 2217 times.
alexone
« on: 22 Sep 2012, 05:43 pm »
James,
all the Bryston stereo preamps have no display (for volume etc...). is this something that Bryston would do on the next preamp models?
and i assume that the new BP 17 has no display, too...correct??
al.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston gear and the (missing) display
« Reply #1 on: 22 Sep 2012, 06:00 pm »
James,
al.
Correct - only the SP3 has a display at this point.
James
Elizabeth
« Reply #2 on: 22 Sep 2012, 09:44 pm »
Just a comment. I would not want a display panel on my preamp.
A display generally causes some noise to be injected into the signal.
I have zero need of any sort of optical  display on my preamps. (or amps)
However I DID add a pencil lead thin strip of white material in the knob groove, on down over the face to allow a quick easy visual of the volume position. I also have one on the selector knob.
Did the same thing to my Audio Research Sp-15 knobs.
And prior to those on my Adcom 750 preamp.
Then, at a glance, from across the room I can see the position.
nemir
« Reply #3 on: 23 Sep 2012, 01:19 am »
Just a weird question about that SP3 display....  Where do you source that part?   Would you be willing to give me a part number?
Cheers!
« Reply #4 on: 23 Sep 2012, 01:51 am »
Cheers!
I will ask engineering.
James
redbook
  • the music is the blood...........
« Reply #5 on: 23 Sep 2012, 08:43 pm »
 I agree with Elizabeth . This is why I'm so glad that the BCD-1 has a turnoff display mode  :thumb: good call.
JfTM
« Reply #6 on: 24 Sep 2012, 11:54 am »
I vote no display, other than where required for functionality (e.g. BDP).
The simpler the better!
95Dyna
« Reply #7 on: 24 Sep 2012, 01:13 pm »
+2!  The BP26 is fine just the way it is, no nonsense with everything you need in a 2 channel preamp.  Well, maybe replace one of the two single end outputs with a second balanced output.
RonCH
« Reply #8 on: 24 Sep 2012, 01:49 pm »
I wouldn't like to see a display on a two channel Bryston amplifier, although I find the displays on current Bryston products to be too small.
