bluetooth keyboard and mouse fot htpc?
0 Members and 1 Guest are viewing this topic. Read 1724 times.
Austin08
« on: 20 Sep 2012, 10:20 pm »
I am interested in buying one of those bluetooth keyboard & mouse but don't know which one to get. Look like the Logitech mx5500 is a winner. (My lab top is hard wire to my tv and my usb dac). What is    your though? Thanks.
ctviggen
Re: bluetooth keyboard and mouse fot htpc?
« Reply #1 on: 21 Sep 2012, 01:06 am »
I just use a remote (RF, connected to IR in on a HT pc; actually, two remotes for two different HT pcs).   I use WMC.  A remote is perfect.  I guess if you're going to type you might need bluetooth.  I usually just use a USB-attached transceiver, since bluetooth doesn't have great range and I need something that works from a long distance.
JRace
  • Greetings one and Everyone!
« Reply #2 on: 21 Sep 2012, 02:04 am »
I use the Logitech K400:
http://www.logitech.com/en-ca/keyboards/keyboards/wireless-touch-keyboard-k400
Small, light weight and has trackpad.
Austin08
« Reply #3 on: 21 Sep 2012, 02:48 am »
How far does this keyboard work in your room? Does it be able to see through cabinet door? Thanks.
JRace
« Reply #4 on: 21 Sep 2012, 05:02 am »
I have used it up to 12 ft (specs say up to 33) and its in a cabinet.
Austin08
« Reply #5 on: 21 Sep 2012, 05:22 am »
Thanks, guys.
Bob in St. Louis
« Reply #6 on: 22 Sep 2012, 05:01 pm »
Tigerdirect has quite a few to choose from.
