BCD 1 Remote
0 Members and 1 Guest are viewing this topic. Read 1207 times.
1ZIP
BCD 1 Remote
« on: 20 Sep 2012, 05:25 pm »
Tried to use the remote today and it's dead.  I'm assuming the batteries have given their all.  Anything to be careful of before I open the thing up?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BCD 1 Remote
« Reply #1 on: 20 Sep 2012, 05:49 pm »
Is it the BR2 remote - if so make sure you push the CD button on the remote.
james
1ZIP
Re: BCD 1 Remote
« Reply #2 on: 20 Sep 2012, 07:25 pm »
It's the one that came with the unit not the the BR 2.  I guess I'll have to reset some codes after battery replacement.
