My amp/preamp problem has been solved.
0 Members and 1 Guest are viewing this topic. Read 1273 times.
Merle
    • http://www.audiocircle.com/circles/modules.php?op=modload&name=gallery&file=index&include=albums.php
« on: 7 Jun 2004, 10:45 pm »
It's the preamp. The amp is fine. I took the cover off the preamp and started poking around. While tapping around, I came across a switch. Not sure what the switch does but as soon as I tapped it, there was the thump. I've shut the system down to let everything discharge. I'm going to blast the switch with some canned air, move it back and forth a few times and see if it's gone. I've talked to Rogue. If I am not able to fix it myself, they will do it for me. At least now I'm pretty sure what it is.
