0 Members and 1 Guest are viewing this topic. Read 14446 times.
I don't understand the premise. You need welding cable for speaker wire?...
should speaker wire series resistance not exceed amplifier output impedance?
To further expand, if no crossover network is used, a SS amplifier with very low output impedance (Z), the DC resistance of the voice coil is zero, the speaker wire could lower the damping factor by up to half.However, since the DC resistance of the voice coil is several ohms, the damping factor change is very small. For instance, 1) an "8 ohm" speaker and 2) DC voice coil resistance of, say, 5.5 ohms (please specify if smaller resistance has been found), and 3) amplifier output impedance of zero ohms 4) the damping factor at 8 ohms is 1.454. 5) at 5.7 ohms minimum Z, the damping factor would be 1.036. Even at this low damping factor, the wire would cause minimal change.Depending upon the crossover frequency and say, a woofer's resonance peak of 40 ohms, the maximum damping factor would be approximately 7.27. Adding a typical crossover would decrease the damping factor further.Midrange and tweeter would also apply, with damping factor also varying with frequency. Imo, wire size would minimally affect damping. With other types of speakers, the damping factor could be less.Cheers.ps. A piezo tweeter would be an exception as it normally has a high impedance and no crossover is often used.
Steve,Your assertion is that transducer Rvc is part of the source and not the load? (At least with regard to damping factor computation?)Well, that's a novel way of looking at it. Cheers,Dave.
If one does a thevenin equivalent circuit analysis (see photo below), the DC resistance of the voice coil appears in series with the output Z of the amplifier (assuming no crossover is used that would add to the resistance/reactance in series).
Steve,I understand Thevenin equivalents. We're talking about damping factor here.In your previous post you made a simple damping factor computation of 1.454 (8 ohms divided by 5.5 ohms.) That's where your error was made and your explanation needs to be directed to.Cheers,Dave.
