FS: Polk SRH1000 Sirius Tuner
0 Members and 1 Guest are viewing this topic. Read 1208 times.
fz1jmp
« on: 17 Sep 2012, 03:48 pm »
I never thought I would part with this unit, the sound is excellent and it gives me all my Sirius music in an excellent form.
I give it a 8/10 for a very small missing fleck of paint on the left side panel and one on the top. They are not seen when viewed from the front. Otherwise it is like new.
It has toslink and RCA outs.  bought this unit as new old stock about 2 months ago and was using it via the toslink output to my DAC. It also has analog RCA outputs.
Come in the original box with everything that came with it new: remote, antenna, rackmout ears etc.
It's a good deal at $150.00. I will cover pp fees, we split shipping in the CONUS.
Here is the details from Polk;
Polk Audio Sirius Satellite Radio Home Tuner - SRH1000
The latest component home tuner from Polk Audio Designs has a unique, innovative look and it adds all of the latest Sirius features and RS232 control for use with high-end integrated home systems. Plus, it can be controlled from
accross the room or even in another room right from your TV screen.
Features:
6-line, front panel graphic display
TV screen graphical user interface
SIRIUS replay™: pause, rewind and replay up to 44 minutes of live radio
Preset memory, S-Seek Alert™, GameAlert™, My GameZone™
RCA stereo and optical digital outputs
RS232 port for external control systems
5-12v remote trigger input
Listen to two different channels in two different rooms at the same time by adding the SiriusConnect Home Tuner or the SiriusConnect Home Dock to the SRH1000 and your existing two-zone audio system
Specifications:
Audio Output: 1V (Peak-to-Peak)
Total Harmonic Distortion (THD) : <0.3%
Signal-To-Noise (S/N) : Greater than 75dB
Power Requirements: AC120 ~ 60Hz,1.5A
Operation Temperature: 0°C ~ 70°C (indoor home or office environment)
Remote Control Battery: AAA (x2)
Approximate Dimensions:
Width: 14.75"
Height: 2.75"
Depth: 10.625"
Approximate Weight:
Unit: 4 lbs
Shipping: 5.5 lbs
fz1jmp
Re: FS: Polk SRH1000 Sirius Tuner
« Reply #1 on: 27 Sep 2012, 01:09 pm »
Bump
