0 Members and 1 Guest are viewing this topic. Read 6351 times.
Whats the difference between Neo3 and Neo8....i see they look preety same till 18khz or i am not reading it right.....i just got a pair of Neo8 instead of Neo3....can you share your experience with these drivers...V
The 3 and the 8 are quite a bit different. The Neo3 is a tweeter and the Neo8 is more of a mid-tweet. The 8 has roughly 3 times the surface area of the Neo3. This is up to personal preference of course, but the Neo8 can be run down to about 500-600 hz on a baffle or in an enclosure, and the Neo 3 is only good down to about 2k. Some run it lower with steep filters, I don't like it any lower than 2.5khz. I think the Philharmonic line of speakers uses the Neo8.It really depends on what you're doing/what your goals are if you want one or the other.....or both. The fr of each really isn't that close when you look at it closer, though they do follow the same general trend of constant directivity (when baffle-less) up to an on-axis dip dictated by the width of the driver, followed by beaming. The Neo8's on axis dip comes in at about 5k, the Neo 3 about 7k. The 8 is beaming like a laser by 10k, but the Neo3 does ok till about 15khz. My goal was constant directivity to 20k. That's not attainable with real-world drivers, but the Neo3 is much better than the 8 in the top octaves.All that said..........I really like the Neo8's. They replaced Fountek FR88-EX's in my speakers, and the difference was like night and day. I won't go into any flowery audiophile descriptions, but I will say the search was over for an upper mid once I got the 8's.What will you be using your Neo8's for?
Hey Nate - what are you using for an XO and amps? Looks like a lot of headroom would be necessary to EQ that response.
