SOLD SOLD SOLD - Musical Fidelity A5 power amplifier. Exellent Cond. $1175
0 Members and 1 Guest are viewing this topic. Read 3360 times.
jaxwired
SOLD SOLD SOLD SOLD SOLD SOLD
Great amp, great condition, great price!   $1175
Ships in original box via fed ex ground insured. Buyer pays shipping. I will cover paypal fees.
I only accept paypal, I only ship to your paypal address.
I have a long history of feedback with audiogon under this same user name.
Specs:
Output : Power : 255 Watts per channel into 8 Ohms (24dBW),
416 Watts per channel into 4 Ohms
Voltage, RMS : 45.2 Volts 20Hz to 20kHz
Voltage, Peak-to-peak : 118.8 Volts
Current peak-to-peak 200 Amps
Damping factor : 170
Output devices per channel : 8
Line inputs :
Total harmonic distortion + noise, < 0.01% 20Hz to 20kHz
Signal / noise ratio > 109dB ‘A’-weighted
Input sensitivity for 255 Watts into 8 Ohms 1.5V
Input impedance 100k Ohms
Channel separation > 90dB typical
Frequency response 10Hz to 100kHz, +0, -1.5 dB
Inputs : “A” 1 pair line level RCA connectors
“B” 1 pair line level RCA connectors
Outputs : 2 amplifier channels via 2 pairs per channel binding posts
1 pair RCA loop output sockets
Power requirement : 100 / 115 / 230Volts AC 50 / 60Hz (factory pre-set),
750 Watts maximum into 8 Ohms, 70 Watts idle
Weight : 19.1 kg, 42.1 lbs unit only, unboxed
23.75 kg, 52.4 lbs in shipping carton
Dimensions : 440 mm, 17.3 inches wide
125 mm, 4.9 inches high including feet
400 mm, 15.75 inches deep including terminals
Standard accessories : IEC type mains lead (10-Amp type)
« Last Edit: 17 Sep 2012, 07:57 pm by jaxwired »
Chipbyrd
That's sweet.  I have been casually looking (meaning without my wife's permission) for the A5 integrated.  I owned one and sold it.  Huge mistake.  MF knows how to make music sing.
Best wishes on your sale.
