Will this mod decrease fuse rating?
0 Members and 1 Guest are viewing this topic. Read 1442 times.
James Romeyn
« on: 13 Sep 2012, 05:57 pm »
Per experience with one premier audio designer and a team of designers including HP's former top trouble shooter (final diagnostician for the Pentium chip prior to release), it is difficult to overstate audio performance upgrade via mechanical damping (clear silicone sealant, epoxy, etc.) applied to caps, fuses, chassis, resistors, transistors, etc.
I consider applying silicone around OEM Hypex Ncore fuse.  How likely would silicone trap heat, thus causing premature failure?
Speedskater
  • Kevin
Re: Will this mod decrease fuse rating?
« Reply #1 on: 14 Sep 2012, 01:23 pm »
Well a fuse acts as a temperature sensing device.  As the current through the fuse increases, the fuse element gets hotter & hotter until it melts!  So thermal insulation will cause the fuse to trip at a lower level. So premature release yes, but it's not a failure.
James Romeyn
« Reply #2 on: 15 Sep 2012, 04:59 am »
Yes, I suppose the mod is the failure!
I suppose same outcome with plumber's tape wrapped around the fuse?  Guess I'll just try it and make sure I have spare fuses available.
satfrat
« Reply #3 on: 16 Sep 2012, 12:44 am »
It's probably why Audio Magic uses a polymer inside their Nano-Liquid fuses. You get your mechanical dampening w/o the overheating.  8)
Robin
andyr
« Reply #4 on: 16 Sep 2012, 03:00 am »
I suggest you use so-called "ceramic" fuses, not conventional glass-tube fuses.  :)  Then you don't have to apply damping substance around the glass.
Andy
