Tivo Stream
0 Members and 1 Guest are viewing this topic. Read 1152 times.
Philistine
Tivo Stream
« on: 13 Sep 2012, 01:25 pm »
Picked up a Tivo Stream yesterday, allows me to stream recorded shows, live shows (with a few seconds lag) and download recorded shows.
Only works on iOS devices, no compatibility with OS X.
So far it works great, anyone with a need for this it's a great solution.
jarcher
  • It Just Sounds Right
Re: Tivo Stream
« Reply #1 on: 13 Sep 2012, 06:43 pm »
Can you confirm that basically you're limited to viewing on your home network, or downloading to your iDevice?  Reason I ask is I thought about this as an alternative to a slingbox, but it doesn't seem like you can view outside of your home network.
Philistine
Re: Tivo Stream
« Reply #2 on: 13 Sep 2012, 07:04 pm »
Your correct, it doesn't have the same functionality as a slingbox and you can only download or view on the same network...
Doublej
Re: Tivo Stream
« Reply #3 on: 13 Sep 2012, 07:22 pm »
I wonder if the issue of local network access only could be addressed by establishing VPN access into one's home network.
