0 Members and 1 Guest are viewing this topic. Read 5946 times.
"The high level inputs on the SPA250 are specifically intended for use with an amplifier that does not have a low frequency line out (sub preamp output). The sub amp takes its signal from the speaker level inputs, left and right, through a high-resistance voltage divider circuit. It does combine the channels to mono, it will not "load" the tube amp at all being connected this way. If you connect your stereo speakers to the high level output on the SPA250, they will be high passed at about 150 Hz (bass rolled off). If you would prefer they run full range as usual, connect them directly to the tube amp. "
