Tube problem?
0 Members and 1 Guest are viewing this topic. Read 1365 times.
TJHUB
Tube problem?
« on: 8 Sep 2012, 07:09 pm »
I'm hoping someone can help me understand a little something about tubes and an issue I'm currently having.
I have an Eastern Electric Minimax DAC Plus.  I purchased a NOS Radiotechnique 12AU7 tube that sound nice totally, but also sounds sort of distorted and smears my sound stage.  I told my friend this, and he loaned me a Herbie's tube damper.
Installing the tube damper Has really improved things and thebsound is great.  My question is why?  Is this tube micro phonic?  Is it bad?
Another thing that bugs me is that my DAC comes with a metal sleeve with a spring in the end to cover the tube and hold it in place.  Why does the tube damper sound so different from this spring loaded sleeve?
Is this normal, or should I seek out a different tube?  And for the record, I do have other tubes that work fine in the DAC, it's just that this tube has better overall sonic characteristics.
Thanks.
richidoo
Re: Tube problem?
« Reply #1 on: 8 Sep 2012, 07:54 pm »
All tubes are microphonic to some degree.  A Herbie's tube damper reduces the vibration of the glass envelope which usually reduces vibration of the critical elements in the tube. It's like putting your hand on a ringing bell. The mass and internal friction of your hand absorbs and converts the vibration motion into heat. Herbies dampers have small amount of internal friction in the soft rubber part of the damper, but mainly the mass does the work by lowering the resonant frequency of the tube envelope to a frequancy that is far below the resonant frequency of the internal parts of the tube where the microphonics happen. Microphonics can cause linear and non linear distortion.  Distortion is not always bad, it is just a tool for tuning the system to taste. Few people prefer a very low distortion system for music enjoyment at home, so the sport is all about finding the quality and quantity of distortion that pleases you. Sounds like you have tweaked it to you liking!
The metal tube cover is to protect the tube from EMI, in this case, low frequency magnetic field of the power transformer, and/or high frequency radio signals. The metal cylinder is like a bell, with high Q and low damping so it wants to vibrate at it's specific frequency. The spring also has high Q resonance with low damping. Both are easily excited to vibrate and ring with relatively pure notes for a relatively long time compared to the signal in the tube.  The ringing metal causes sympathetic vibrations of the metal parts inside the tube, which affect the sound of the signal. So the metal shield adds vibration to the tube, and the damper removes vibration from the tube, that's why they sound different.  On less microphonic tubes, the difference would be less obvious.
You can also damp the metal shield to stop it from vibrating while retaining the EMI protection. Before herbies, people used rubber O Rings for damping tubes. They would sometimes melt onto the tube, but it still worked. The metal shield is much cooler than the tube so a bunch of O rings stretched over top would damp it nicely, or some high temp tape, or use your imagination. Buna-N is common material for o-rings but it has a low melting temp of 250F. That should be enough for a shield or signal tube, but there are others that can take more heat.  MSC Direct is a good place to order industrial stuff like that.
Remember that distortion is good, if it is the right flavor, so don't assume that damping all vibration is best. Vibration is a spice, experiment and learn to use it.
In my opinion, if you found a tube that you like, it is worth the effort to give it the extra attention it needs to reach its full potential, rather  than choose a lesser tube that needs less fuss. Hifi is an art, and you as the artist, should enjoy the fiddling. The downside of tubes is that they require more attention, but the payoff can be big once you learn their strengths and weaknesses.
TJHUB
Re: Tube problem?
« Reply #2 on: 8 Sep 2012, 08:08 pm »
Thank you for the excellent response.  I really appreciate it.
My listening since my original post has proved to be amazing.  I have rolled enough tubes in the past to realize how difficult it is to find the "right" tube.  This one is it for sure.  Now that the metal sleeve is off and the tube damper is on, the change in clarity, separation, and imaging combined with this tube's tone is sounding nothing short of amazing.  Had you said the tube should be discarded, I would have ignored you the sound is so good.  But I'm very glad you didn't say that.
I'll have to really thank my friend for thinking of the tube damper and loaning me one to test with.  Looks like Herbie's getting an order today.
Thanks.
