0 Members and 1 Guest are viewing this topic. Read 17387 times.
Let me add some more to my story and I hope at least your enjoying it. I found a 1/2A fast fuse in my Mc tuner. Then, I decided to call Cary. The person who I spoke with, not Dave like I said yesterday, Mark was a sheer pleasure to talk with. I was taking tubes out and sticking the multimeter leads in slots like I knew what I was doing! Turns out its a fixed bias amp, which surprised even him. When I verified, but black on ground and red in slot 5, that each socket was controlled by the 1 bias adjustment. The amp was definitely biased too low when I got it, hence the horrible sound. I finally biased it at 200ma, which he said should be 50ma per 6550. KT88's would be more like 240-250. I think I may just listen to the music now, and pick up a quad of GL's. I saw a decent price of less then $200 from a decent vendor. Thanks everyone for your help and comments, invaluable!!!
Mario; Mark was a gem and I thank you for the suggestion! He certainly spoon fed me and taught me as much as I could learn. I did mention to him I was thinking of putting in the GL KT88's and he said then I should raise the bias to 240 - 250. I'm going to re-pour over the forums regarding plate voltage. He mentioned that I could bias it as Class A or AB (?) and that AB would be 50%? But he said so much and I was just trying to keep my head above water quite honestly. I sat back and put on MOG (squeezebox duet) and listen to a variety of tunes and I have to say it put a smile on my face.
hi jack,it seems you have finally gotten these amps working properly, good news! here's a suggestion for you. since the speakers you are using, klipsch cornwalls, are wery efficient (98.5 to 102 db/1w/1m depending on series), you may want to consider having your amp converted to triode from ul. your speakers would likely sound better w/the triode setting, and 15wpc in triode will still be plenty of power to drive your klipsch's to extremely loud spl's, even in a big room. and, maybe it is possible to wire it w/a switch to allow changing from triode to ul on the fly. you might wanna contact cary again, to get their input on this...doug s.
Mark from Cary should be able to tell the proper bias for your amp.
All of the fixed bias amps that I have encounterd had a trim pot for each output power tube. That is how you are able to set the bias current to exactly X mA per tube and match the bias for the set.
I have a parallel and a push/pull that have a pot for each pair, just need to run matched tubes.
Not sure why you quoted my response to Quiet Earth. I was just pointing out that there are a variety ways to skin the cat concerning manual bias.
All of the fixed bias amps that I have encounterd had a trim pot for each output power tube. That is how you are able to set the bias current to exactly X mA per tube and match the bias for the set. How are you supposed to set and match four tubes at the same time with one bias pot on this amp? I'm having trouble visualizing it from the descriptions.
