0 Members and 1 Guest are viewing this topic. Read 17340 times.
An amp's output impedance will affect bass output (so may be beyond tube rolling).Consider doing one or some of the very simple, well-documented crossover mods to lower the output of the midrange squawker and tweeter relative to the woofer. Generally speaking, this restores the speaker's bass balance. The Klipsch forum is a great place for this.
1. It had a bias adjustment screw on the back, even though its auto-biasing. Well there is also a input jack, which I thought was a headphone input! TUrns out thats where you check the bias current! Can I use a simple voltmeter? He said he should be about 120mv, 30 X 4, I got that. But then he said use the 200mv scale?Can I just turn it all the way counterclockwise and slowly turn it as I listen?
Well, as long as you are having fun then that's all that really matters. When you said "He said he should be about 120mv, 30 X 4, I got that." earlier in the thread, I thought you meant that you got the bias set. If you are just turning the screw without monitoring the bias, I would learn how to bias the tubes properly or your fun might not last as long as you want it to.Keep working at it . . .
So, could a slight bias shift make this much of a difference?
I'm way out of my league here !!! I figured, let me call AES, well Cary and just ask them about this amp. I spoke to a very very knowledgable person, Dave. I gave him my serial num and he said, hummmm, that has a bunch of tweaks you did not see on later models. So, 3 things I have no idea what he was saying; 1. It had a bias adjustment screw on the back, even though its auto-biasing. Well there is also a input jack, which I thought was a headphone input! TUrns out thats where you check the bias current! Can I use a simple voltmeter? He said he should be about 120mv, 30 X 4, I got that. But then he said use the 200mv scale?Can I just turn it all the way counterclockwise and slowly turn it as I listen? 2. The review says it used 6922's, not the 6550's? Huh? Can I replace the 6550's with 6922's? 3. What the heck is the difference between tetrode and pentode mode? And sound? I hope I'm not reaching with these questions, I would love to hear what this amp can do, I don't think I am.
I'm assuming that I cant just splice a headphone wire onto a lead on my voltmeter, where would I put the negative?
I'm going to apologize in advance, I'm not quote sure why the pic is upside down. The input jack next to the fuse is the bias port I was told. Can I just stick in the probe? And the other on the negative speaker terminal? Dave added up the quad and said 120. That I can figure out. Now, the idea of sending it back for a bench check, I did not think of that! Yes, the tweaks were all performed by AES as they were prototyping the amp, thats what I was told in great detail by the seller. Who, again, I find no fault with at all. We struck up a nice 'audio' friendship, he is an older retiree who enjoys his audio!I'm sorry if I confused you, but yes its wired for Ultralinear. What exactly does it mean sonically? I tried researching it all day and really have no additional idea. BTW, I took a sick day today and again, enjoyed audio in 1 form or another all day.munosmario; you seem to think its truly worth it, I so dont want to throw good money after bad. I actually put it on 'gone for what I paid. But now I'm tempted to pull it. The aleph 2's are good, but they just don't have that sound I seem to be looking for. I actually bought the Cornwalls just for there efficiency and figured they would be a perfect complement to the AES. Anyway, great readings!!!PS - I wish I had the manual, Cary does not have one either.
