SOLD-Emotiva UMC-1 7.1 Channel Pre/Pro-$450.00
0 Members and 1 Guest are viewing this topic. Read 868 times.
pdaddy
« on: 3 Sep 2012, 01:47 pm »
I have an Emotiva UMC-1 Audio factory refreshed 7.1 Channel Preamplifier/Processor for $450.00. Free Shipping. Full 5 year warranty!
Twin Cirrus® 32 bit dual core DSPs.
Decoding support for Dolby Digital, Dolby Digital EX, Dolby Digital Plus, Dolby Digital True HD, Dolby PLIIx, DTS, DTSES, DTS HD, DTS Master Audio, DTS Neo 6, SPDIF, PCM 8 channel (note: some audio formats are only supported via HDMI).
Multi-channel Dolby Volume.
Genesis/ST® Torino high performance scaling engine - featuring a full implementation of the Faroudja DCDi™ image processing suite.
Intuitive, full color graphical OSD with adjustable transparency presented over live video, including HDMI.
Emo-Q™ automatic multi-channel room correction and loudspeaker setup. Calibrated measurement microphone included.
Quadruple bass manager with independently selectable high and low pass frequencies from 40hz – 250hz, in 5 or 10Hz increments (depending on frequency).
Selectable 12 dB or 24 dB per octave high pass and low pass filters by channel groupings.
Independent 11-band graphic EQ with global bass and treble controls by channel groupings.
Balanced subwoofer output.
All legacy video inputs can be scaled and output over HDMI at up to 1080p.
1080p/24 fps video support.
Video pass-through mode with 12 bit compatibility.
HDMI sources can be format converted to component video up to 1080i (subject to Macrovision™ guidelines).
HDMI 1.3a Deep Color compliant.
All inputs are assignable and feature input labeling, selectable decode modes, selectable triggers, etc.
0.5 dB level trims on all channels.
High voltage, low impedance main analog outputs for uncompromised dynamic headroom.
« Last Edit: 3 Sep 2012, 11:47 pm by pdaddy »
srb
Re: Emotiva UMC-1 7.1 Channel Pre/Pro-$475.00
« Reply #1 on: 3 Sep 2012, 02:35 pm »
Shipping paid by buyer or included in price?
« Last Edit: 3 Sep 2012, 07:00 pm by srb »
pdaddy
« Reply #2 on: 3 Sep 2012, 05:58 pm »
Thanks SRB. I will update.
