Sherbourn SR-120 HDMI 7 Channel Home Theater Receiver-$798.00
0 Members and 1 Guest are viewing this topic. Read 1650 times.
pdaddy
I have a new in box Sherbourn SR-120 7 channel home theater receiver. This thing is a beast and will blow the doors off any typically name brand home theater receiver and with a 5 year warranty! Retailed for $2999.99
The specs speak for themselves:
• Decoding support for Dolby Digital, Dolby Digital EX, Dolby Digital Plus, Dolby Digital True HD, Dolby PLIIx, DTS, DTSES, DTS HD, DTS Master Audio, DTS Neo 6, SPDIF, PCM 8 channel , true processing up to 196kHz
• Twin Cirrus® 32 bit dual core DSPs
• Multi-channel Dolby Volume. Genesis/ST® Torino high performance scaling engine featuring a full implementation of the Faroudja DCDi™ image processing suite
• Sherbourn, full color graphical OSD with adjustable transparency presented over live video, including HDMI
• Front panel surround mode indicator lights
• RS-232 two way communications for independent computer control
• Sherbourn automatic multi-channel room correction and loudspeaker setup. Calibrated measurement microphone is included
• Quadruple bass manager with independently selectable high and low pass frequencies from 40 Hz - 250 Hz, in 5 or 10Hz increments
• The PT-7020A also utilizes a balanced output section. A balanced system minimizes noise that may enter the processor via external input cables. Especially in cases where very long lengths of cable are being used, balanced connections offer excellent induced noise rejection
• Selectable 12db or 24db per octave high pass and low pass filters by channel groupings
• Independent 11-band graphic EQ with global bass and treble controls by channel groupings Balanced subwoofer output
• All legacy video inputs can be scaled and output over HDMI at up to 1080p 1080p/24 fps video support
• Video pass-through mode with 12 bit compatibility
• HDMI sources can be format converted to component video up to 1080i
• HDMI 1.3a Deep Color compliant
• Assignable inputs featuring input labeling, selectable decode modes, selectable triggers, etc. 0.5dB level trims on all channels
• High voltage, low impedance main analog outputs for uncompromised dynamic headroom
• 1 - IR output (3.5mm mini)
• 1 - Microphone input (3.5mm stereo mini)
• 1 - USB data input (for software upgrades only)
Specifications:
• Frequency response: 20 Hz - 20KHz all channels driven
• THD: 0.05 %
• Power Consumption: 5Hz-150KHz
• Signal to noise ratio: 110 dB/ A weighted
• Sensitivity: 1.1 volts
• Dimensions: 17" W x 14.5" D x 7" H
• Weight: 77lbs
• Tuning frequency range: 87.5~108 MHz
• Tuning frequency response: 10 Hz ~ 100 kHz- +1, -3 dB (DIRECT mode)
• Tuning signal to noise ratio: 110 dB/ A weighted
• Video Format: NTSC
• Video Inputs: HDMI x 5/ Composite x 3/ S Video x 3/ Component x 3/ Stereo x 4/ 7.1x 1
• Power supply: 120v/60Hz or 230v/50Hz
