0 Members and 1 Guest are viewing this topic. Read 40655 times.
Let me first say that I am glad you love your Epik sub. I like the philosophy of the company. I'm intrigued by the operating theory of their subs. It might be the ideal sub to place in the rear of my room (yes, Scotty, that idea is alive and well inside my head). If that plate amp actually bears a sticker stating Made in USA, then I'm mighty impressed. Regardless, it seems like a great bargain, not unlike a pair of MMGs – a good match they should make.Something about your review confuses me, however. On the one hand, you stated that your Magnestand modded MMGs produce more bass than stock, but a different post implies that your Epik Legend is rolled off somewhere in the midbass region. Have I inferred in error?I really only want my subs to contribute what my Maggies don't – deep bass. In my parallel setup with MMGs and REL Q150s, the subs are set at 54Hz – providing plenty of overlap with the elevated MMGs (which are doing their best to reproduce a full-range signal, but failing); higher filter points reenforce frequencies that don't need any help (the MMGs are doing a spectacular job on their own). In my 3.7/DefTech SC Ref setup, a Bryston 10B Sub XO is dividing the chores. The latter is really the best way to go about it – let the subs do what they're designed to excel at doing while relieving the Magnepans of work they're 'happier' avoiding (win/win).Audio systems are journeys. There are many paths through the woods. I recommend that you 'think seriously about' implementing a crossover. There just may be an even better level of integration right around the bend – you're standing so close. Push on mate, push on.BTW, I like your enthusiasm. Enjoyment is the name of the game – this is a hedonist pursuit! ---Davey, that Dayton sub looks like a hell of a bargain! I built a sub for my daughter using Dayton Reference drivers and one of their plate amps - amazingly good stuff for the money.---I definitely subscribe to the 'multiple subs beats one' philosophy...and how!
@Jim Right now I have both RCA's from Output 2 on the Warp combined via splitter to one and this is going to the Legend crossover. So mono. I'd like to run this same cable into something that has a lot of control and multiple outputs, but I will sure put some research into what you have given me
So not being familar with the Warpspeed, are you saying that you are running one set of channels to the Maggies and the other set of channels to the subs? Better said, one set of speaker outs to the maggies and another set of speaker outs to the subs? Jim
Yep, exactly. One set of outs is combined to one RCA, and that into the sub crossover.
