20 amp dedicated circuit for RM20
0 Members and 1 Guest are viewing this topic. Read 932 times.
Robert D
« on: 2 Sep 2012, 12:49 pm »
How much of the reserve will this help out the RM20
As it stands My RM 20 came with 2 ac power cords.
1 - 15amp in use......
1- 20amp
I will be connecting my 2 new Paradigm Sub1 's to my RM 20. The ac power cords going to my RM 20 will be 12/2 shielded.
My 2 4bsst2s have never clipped ..... I'm thinking that putting in a 20Amp dedicated circuit will resolve all of my worries
As of now my Sub1's are plugged in a 15 amp circuit as well in the same room where my Rm20 is plugged. They are on the same circuit.
Feedback would be great..
Regards Robert
Robert D
Re: 20 amp dedicated circuit for RM20
« Reply #1 on: 2 Sep 2012, 01:01 pm »
1- 20amp
Regards Robert
Here are the Specifications on the Subs
If this helps
SPECIFICATIONS
Design Hexagonal cabinet with multiple high-excursion
drivers radially aligned in a Vibration-Canceling
Design Architecture, patented built-in
Ultra-Class-D™ power amplifier, sealed
enclosure, PBK interface, removable grille
Amplifier: High-Current,
Discrete Output 3,400 watts Dynamic Peak /
1,700 watts RMS
Amplifier Features Auto-On / Off, Trigger On / Off, soft clipping,
electrical shorting protection, thermal protection
Bass Driver Six 203-mm (8 in) mineral-filled co-polymer
polypropylene cones, overmolded
FEA-optimized NLC™ surrounds, 38-mm
(1-1/2 in) four-layer long-excursion voice
coils, high-temperature composite Nomex®
formers, advanced spiders, 9.2-lb (4.16 kg)
hard ferrite magnet / motor structure,
AVS™ die-cast heatsink chassis
Low-Frequency Extension* 12 Hz (DIN)
Subwoofer Cut-Off Frequency Variable 35 Hz - 150 Hz; Bypass Option
Sub / Sat Phase Alignment Variable 0° - 180°
Line-Level Input RCA (S/E) Left and Right or Sub-Out / LFE or
Balanced XLR. From Sub-Out / LFE-Out of
preamp, processor or other line-level source
Line-Level Input Sensitivity 100 mV mono
Line-Level Input Impedance RCA: 10k ohms; XLR: 20k ohms
Accessory Included Paradigm Perfect Bass Kit
Height, Width, Depth††
 51.6 cm x 50.5 cm x 45.5 cm
20-1/4 in x 19-14/16 in x 17-14/16 in
Diameter of Hexagonal Cabinet 50.5 cm
19-14/16 in
Weight (unpacked) 49.4 kg / 109 lb each
Finishes Cherry, Piano Black, Black Ash
drummermitchell
« Reply #2 on: 2 Sep 2012, 02:28 pm »
Robert,is everything going thru the Torus(subs,amps ect).
The reason I ask is when I had the 3X7Bsst's and two 4Bsst's+2XDD15's going thru a 15a Torus,everything sounded normal(with dedicated line).
I was using Hydra 6 before,with hydra 2's one for each amp and subs(also dedicated).I couldn't hear a difference between the two,UNTIL.........................
I put in another 20a Torus.
What an upgrade that was,I guess the 15a couldn't give what the amps and subs wanted.
Someone had said to me that having gobs of power in reserve for the amps makes a huge difference.
Gotta tell ya it's not suttle.
I'm thinking what the difference would be for you is your 15a line(non dedicated) and a dedicated 20a line......NO hitch hikers on the dedicated(fridge,air conditioner and your God forbid your swimming pool heater :lol:.
PS:I should add, that  before I had a F-113 sub on a dedicated 20a line(no Torus)and we had a thunder storm here,guess what,the F-113 was toast.
All the rest of  my gear including subs were fine,that I can be quite positive that the Torus had protected everything.
Those subs and I assume yours have digital components in them,which I think can be quite sensitive to a swift kick in the pants from mother nature.
