Tar paper for damping cabinets wall vibrations
0 Members and 1 Guest are viewing this topic. Read 1574 times.
WireNut
« on: 2 Sep 2012, 01:39 am »
Will tar paper work for damping and controlling vibrations of loudspeaker cabinets walls compared to products like bitumen pads, deflex pads, blackhole 5?
django11
  • Canuckistani
Re: Tar paper for damping cabinets wall vibrations
« Reply #1 on: 2 Sep 2012, 12:27 pm »
I am no expert but  #15 tar paper probably would have zero effect.  It is very flimsy and would be difficult to adhere.  I used Ice and Water membrane as part of my cabinet damping to good effect.
gfederys
BUT....
« Reply #2 on: 2 Sep 2012, 12:47 pm »
We have a local autosound place in town. They carry a no-name brand "tar paper like" sound dampening material, that is about 1/8" thick, sticky on one side, and I believe, 30" width. It's affordable, (compare to Deflex or other name brands), and works quite well to stop wall reflections. Check around @ those kind of shops. You'll still need some kind of stuffing if it's an enclosed or ported cabinet.
WireNut
« Reply #3 on: 2 Sep 2012, 04:31 pm »
django11,
Thanks for the tip. I found some online at home depot. About how thick is the product ?
I like the fact that I wont have to use any contact cement since it's self adhesive.
The smallest amount I can find seems to be a 75 foot roll for about $65 bucks.
The pics show two push pull bass cabinets I am currently working on.
