FS: Speakercraft SLS2 - Silver pair - NEW
0 Members and 1 Guest are viewing this topic. Read 1187 times.
KKM
« on: 1 Sep 2012, 02:39 pm »
SpeakerCraft SLS Series On-Wall Speakers Model 2 Tower Pair - $399 plus shipping
Brand new in sealed factory carton.-- two cartons.
Aluminum On-Wall Speaker. Four 3" Aluminum Drivers. 1" Pivoting Tweeter
With the growth of plasma and LCD flat-panel displays, SpeakerCraft was aware of the need to design a speaker that would not only complement such displays, but could also be mounted directly on-wall.
The SLS Two Slim Line Surface Mount speaker features a ported extruded aluminum enclosure, which is only 5 1/4" deep. A solid wood baffle provides a dense non-resonant housing for the multi-driver array.
Four  3 long-throw aluminium drivers work in unison, creating fast accurate bass extension. A 1”, 360 degree pivoting aluminum tweeter completes the driver array. Its pivoting action allows the high frequencies to be directed toward the listening area and reduces the reflected distortion from flat panel displays, which typically sit away from the wall.
Horizontal or vertical mounting and the pivoting tweeter combine to help the SLS Two excel in all multi-channel applications. Center, front and surround channel information can be directed accurately: in surround applications, the high frequencies can be directed away from the listener, creating a more diffuse and enveloping soundstage.
A unique mounting system simplifies installation and a removable cover plate hides all wiring, while still making it accessible after the speaker is mounted.
Brushed aluminum, the SLS Two will look and sound at home in the finest home theaters.
SPECIFICATIONS
2-Way Ported On-Wall Aluminum Speaker
Applications: Critical Stereo & Home Theater
Extruded Aluminum Cabinet
Tweeter Pivoting 1" Aluminum Dome Tweeter.
Woofers: Four 3" Aluminum Drivers.
Impedance: 8 ohms
Efficiency: 89 dB 1W/1m
Frequency Response: 80Hz - 20 KHz ±3 dB
Power Handling: 5-100W (undistorted)
Magnetically shielded: yes
Dimensions: 26" x 8.875" x 5.25"
Weight: 25 lbs (each box)
