Lone Star Audio Fest Sale
0 Members and 1 Guest are viewing this topic. Read 2470 times.
seijinaudio
    • Seijin Audio Junction
« on: 1 Sep 2012, 12:44 pm »
We have finally relocated to Austin, TX and need to make room for the new lines will be distributing.
Have a few products that were used just for the Lone Star Audio Fest in May.  All come with warranties, silver, original packaging and manuals.  Locals are welcome to audition.  Paypal add 3%.
Jolida 202BRC - 699
Jolida JD100A - 725
Jolida JD9 (factory upgraded lvl 1) - 405
-Joshua
jimdgoulding
Re: Lone Star Audio Fest Sale
« Reply #1 on: 10 Sep 2012, 09:44 pm »
I didn't spot those products on the JoLida site.  Mind saying what they are?  Thanks.
seijinaudio
« Reply #2 on: 11 Sep 2012, 01:49 am »
Sure.
JD202BRC
Construction Details and Features:
Fully Integrated Stereo Amplifier: Input 500mV driving 50 watts, maximum 75 watts output
Multiple Inputs: Front mounted selector switch-CD, Tape Recorder, Tuner and Aux. (for TV, VCR or Computer)
Custom Wound Audio Transformers with a core of German grain oriented silicon steel. 15th generation proprietary design. Secondary can be configured for a 4 ohm or 8 ohm load
State of the Art Components: Blue ALPS audio potentiometer, gold plated RCA input jacks
Remote Control
Technical Specifications:
Maximum power Output:    50 W per channel at 8 ohms, 1KHz
Rated Output Power:    40 W per channel at 8 ohms, 30Hz to 80KHz
Frequency Response:    (at 1 watt into 8 ohms) 8Hz to 140KHz + 3dB; 0dB at 1KHz
Bandwidth:    16Hz to 140KHz + 3dB; 0dB = 30 W 1KHz, 8 ohms
Distortion THD + N:    Less than 1.5% at 30 W output, 40Hz to 14KHz, 8 ohms
Circuit Type:    Ultra Linear, Class AB
Input Impedance:    100Kohms
Input Sensitivity:    Max. 250mV at 1KHz for 30 watt output
Output Impedance:    4 ohms and 8 ohms
Noise and Hum:    80dB below rated output
Tube Complement:    2 matched pairs (4) of 6CA7/EL34 power output; 2 pcs. 12AX7A pre-amplifier, 2 pcs. 12AT7 power drivers
Power Requirements:    110V-120 VAC 60Hz 90 watts-standby, 200 watts maximum (220 VAC-50Hz option)
Dimensions:    12.5 inches (30 cm) wide by 12 inches (31 cm) deep by 8.25 inches (21 cm) high.
Weight:    36 pounds (16.3 Kg) net, approximately 38 pounds (17.2 Kg) packaged
Warranty:    One year limited parts and labor. Six months on Jolida Tubes
JD100A
Vacuum Tube Compact Disc Player, 12AX7A Tube Complement
Gain stage utilizing two 12AX7A vacuum tubes. Unit does not utilize op-amps.
Two transformers
24/96 Burr Brown D/A converter
Phillips CDM 12.1 Transport System
Programmable for up to twenty-four tracks.
Full - function random access metal remote control with search function.
Track repeat and index of track search function.
Variable Headphone output.
Frequency Response:    + 0.5dB, 20Hz to 20KHz
S/N Signal to Noise Ratio:    > 102dB
THD + N Distortion:    < 0.01%, 1KHz
Channel Separation:    > 96dB (1KHz)
Line Output Voltage:    > 2V, 100 Kohms
Digital Output:    0.5Vpp, 75 ohms
Headphone Output:    35 mW, 32 ohms
Power:    110V or 220V AC 50Hz/60Hz
Power Consumption:    20 watts
Size:
17 in. wide by 12 in. deep and 3.5 in. high
Weight:    22 pounds
Warranty:    18 months parts and labor
JD9
Phono pre-amplifier that will handle MM, MC and Dynamic head cartridges.
Rated sensitivity at .25 mV – 80 dB.
Two Outputs RIAA, Line stage.
Adjustable gain settings for cartridge type
State of the Art Components: Gold plated RCA inputjacks.
Low profile full body allows the unit to act as a base for your amplifier or turntable. No need to loseanother shelf for a component.
Tube Output
Frequency Response:    5Hz to 110KHz, (+/- 1 dB)
SNR:    > 100 dB
Distortion THD:    Less than .02%
Output Impedance:    600 ohms
Phono Stage:
MM:    60 dB, 5 mV
MC High:    75 dB, 0.5 mV – 1.5 mV
MC Low:    80 dB, 0.25 mV – 0.5 mV
Input Resistance:    100 ohm, 300 Ohm, 1Kohm, 47Kohm
Input Capacitance:    47 PF, 100PF, 150PF, 220PF
Tube Complement:    2 pcs. 12AX7
Size:    17 in. (W) x 13 in. (D) x 2 in. (H)
Weight:    10 lbs., 14 lbs. Boxed
Warranty:    One year parts and labor, Six months year on tubes
jimdgoulding
« Reply #3 on: 11 Sep 2012, 11:28 pm »
Welcome to Austin.  I live in the Houston area but visit often.  That JD9 phono pre-amp SHOULD be enticing to somebody.  It has a fine history.  I have retired from upgrading gear, myself.  All the best, dude.  If I visit your store, I'll ask for Joshua just to say hey.
seijinaudio
« Reply #4 on: 12 Sep 2012, 01:21 pm »
Much appreciated.  Would love to meet when you are out, but won't have anything for auditioning until early next year.  Just liquidating inventory and will be doing distribution of some select audio gear.
