Threaded Stud Glider As Compared To Decoupling Spikes
0 Members and 1 Guest are viewing this topic. Read 3341 times.
ZLS
    What is the difference in sound between the Threaded Stud Glider for Speakers,
and The Decoupling Spikes?
    If The Cone/Spike Decoupling Gliders are added into the equation, Does it change the result?
        Thank You
Herbie
    • Herbie's Audio Lab
Re: Threaded Stud Glider As Compared To Decoupling Spikes
« Reply #1 on: 14 Aug 2013, 12:33 am »
Subtle comparative differences will vary somewhat from one system to another, according to the vibrational environment, system variables and synergies, and personal taste/preference. All use the same dBNeutralizer material that does the job, so sonic results will be audibly similar.
Herbie's Audio Lab
