Using a quality stereo amp for 5.1 sound
0 Members and 1 Guest are viewing this topic. Read 987 times.
MRC
« on: 23 Aug 2012, 01:24 pm »
Hi, it's my first time here...
I prefer the qualities of a good old stereo amp and a good set of speakers, although I'm sure a dedicated 7.1 receiver delivers lots of excitement...
Still, I've plugged my Sony Blu-Ray to a Bravia through HDMI, used the analogue audio out RCA's from the Bravia to connect to a stereo amp, and I'm getting some nice results.
Question is:
The Blu-Ray has a stereo/surround downmix option, AND the Bravia also has a stereo/surround downmix option (when you select "audio system" from the tv menu, and go to advanced options).
Well, I'm using a stereo amp with the Bravia serving as a receiver/preamp. The Bravia has Dolby Digital Plus circuits, of course.
How should I set up the downmix options for multichannel discs?
Thanks.
Mr Peabody
Re: Using a quality stereo amp for 5.1 sound
« Reply #1 on: 1 Sep 2012, 05:06 am »
I'm not familiar with the Bravia set up but if you are getting a stereo signal from the analog (L/R) outputs the TV must automatically mix down any 5.1 or multichannel audio signal before outputting to the stereo analog outputs..
