VPI Periphery Ring... HOW not to install!
0 Members and 1 Guest are viewing this topic. Read 13148 times.
Sonny
« on: 22 Aug 2012, 08:33 pm »
So, take a look at he picture below...what do you see about the ring and how it's installed?
Bonus question, what Show and year of the show was this at?
tomytoons
Re: VPI Periphery Ring... HOW not to install!
« Reply #1 on: 22 Aug 2012, 08:50 pm »
That looks as though the ring is NOT on the record but under it.
Show??? Year??
Sonny
« Reply #2 on: 22 Aug 2012, 08:53 pm »
Show??? Year??
Right!  Apparently this picture was taken at a CES Show in 2007.  So, looks like the person(s) demoing the VPI table didn't know how to install the ring.  A shame!   :duh:
tomytoons
« Reply #3 on: 22 Aug 2012, 09:31 pm »
I'll say.....that's quite dumb :duh:
putz
« Reply #4 on: 23 Aug 2012, 12:27 am »
Was this the VPI room? Many speaker/amp manufacturers use VPI tables to demo their gear. Harry goes to most shows and can't imagine him doing that. Can't be good for the VTA either.
J-Pak
« Reply #5 on: 23 Aug 2012, 12:50 am »
It might sound better that way, make the LP decouple from those dull sounding acrylic platters  :icon_twisted:
kgturner
« Reply #6 on: 23 Aug 2012, 01:01 am »
To play devils advocate, I have one or two LPs in my collection that are "undersized" so that the ring does not fit on them and just slides down the platter to the stopping point. I leave it on anyways when I play this LPs because my SDS has been adjusted with the added weight of the ring and center weight.
Kevin T
Minn Mark
« Reply #7 on: 23 Aug 2012, 03:50 pm »
I got to thiniing about a ring +/- weight for my Classic I after getting a very clean but slightly warped LP yesterday from eBay. (Mick Fleetwoods Zoo, Im Not Me)
Can I use the ring on my Classic I without SDS ?(I dont have SDS)
I use either the supplied clamp or I have the TTW weight/clamp which does not seem to effect the speed.
Thanks for response.  PM me if you like to keep this thread clean.
M
kgturner
« Reply #8 on: 23 Aug 2012, 06:23 pm »
I used the ring and center weight on my Scoutmaster before I ever owned the SDS so I see no significant issues why you couldn't use the ring with your Classic. I calibrated my speeds with the weight of the ring, center weight, and needle drag all in place on my Aries 3 so now I just make sure to use them just in case.
Kevin T
Sonny
« Reply #9 on: 23 Aug 2012, 06:53 pm »
M
you should be fine, as long as the platter is spinning at the right speed.  I used it on my Classic and didn't notice any Slow down in RPM.  At least by ear anyways. :thumb:
jtwrace
    • TIPP YouTube Channel
« Reply #10 on: 23 Aug 2012, 06:57 pm »
Which will yield the larger sonic result?
SDS or Ring?
Sonny
« Reply #11 on: 23 Aug 2012, 06:58 pm »
SDS or Ring?
Having both...I would say SDS as that stabilizes speed...and ring is good, but the clamp system is good enough, unless record is really warped!
jtwrace
« Reply #12 on: 23 Aug 2012, 07:05 pm »
Gotcha.
twitch54
« Reply #13 on: 23 Aug 2012, 08:12 pm »
Kevin T
Bingo...........Kevin you are correct, while the ring is designed to help flatten by contact on the outer edge of the LP there are Lp's were that won't work.
I suspect in the demo room that Tuan's pic portray's there may well be a bit of laziness going on !
twitch54
« Reply #14 on: 23 Aug 2012, 08:14 pm »
SDS or Ring?
As Tuan said, the SDS is superb but I must admit I like having both.
roscoeiii
« Reply #15 on: 23 Aug 2012, 08:54 pm »
Haven't sprung for the SDS, but have liked what the PLC has done for my system. Speed stability and makes it easier to insure that both 45 and 33 1/3 RPM are spot on (not usually the case by just moving the belt to a different sized pulley, IME).
How much difference above the PLC would an SDS make?
roscoeiii
« Reply #16 on: 23 Aug 2012, 08:55 pm »
If I had a Periphery Ring, I would put it on the table along these lines:
http://www.youtube.com/watch?v=JIoQyOHqgAw
TheChairGuy
« Reply #17 on: 23 Aug 2012, 11:11 pm »
SDS or Ring?
VPI's official line on that is ring first, SDS second in that order.
The Classic is already more speed stable than the HW-19 and much of the Scout line I've heard.  I'm really sensitive to this as I listen to a lot of solo piano and except for the slightest deficiency versus the JVC direct drive reference in that regard, it's stellar and solid sounding for speed.
I assume a ring and an SDS is a pretty great standard of playback for USD$4500. But it's good enough for my needs with ring alone, tho.
jtwrace
« Reply #18 on: 23 Aug 2012, 11:44 pm »
Thanks ChairGuy
Can someone take some pics of how the ring really works?  Is it another time consuming step?
Sonny
« Reply #19 on: 23 Aug 2012, 11:48 pm »
Thanks ChairGuy
here you go...
