Which cart for Music Hall 7.1
0 Members and 1 Guest are viewing this topic. Read 1202 times.
bajaed
« on: 22 Aug 2012, 05:57 am »
Looking for a replacement for my Goldring 2400 on the MH 7.1. I'm considering the Ortofon 2M Black, Benz Micro ACE(L, M, H?) and the Nagoaka MP-500.
My other components are a Jasmine LP MK II phono amp(MM and MC, lot's of adjustments) Rogue Cronus Magnum and Energy RC-10 speakers(will be replaced sometime after cart upgrade).
Any thoughts on the sound of these carts considering my equipment? Any other choices?
jimdgoulding
Re: Which cart for Music Hall 7.1
« Reply #1 on: 22 Aug 2012, 11:58 am »
The Benz has a very good rep as I recall.  You can probably find some reviews online.
bajaed
« Reply #2 on: 22 Aug 2012, 09:57 pm »
Yes I have found some great reviews on all 3. Each would sound different in my system and I'm trying to get some feedback as to how they may sound with my table amp and phono stage.
rick_reynolds40
« Reply #3 on: 23 Aug 2012, 09:35 pm »
I've had a very good results with the At150mlx, Denon Dl-110 and Ortofon Rondo Red on that table.  Currently using the Rondo Red and it is the best I have tried on that particular table.  Heard the 2M Black on a few different tables and it is an excellent choice as well.  Never tried the Benz.
