0 Members and 1 Guest are viewing this topic. Read 12305 times.
I felt the sub bottom as you asked and there is no vibration, it is totally inert enclosure based on the design of parallel sealed drivers.The Seaton Submersive is a large room, high power version of this concept. Never see them on platforms either.
Jim,Please define what you mean by "standing waves."I agree that isolation from a typical wooden framed floor would be beneficial as that type of floor represents a huge diaphram, but not if supported by a (relatively massive) concrete slab. In that case the sub would be less coupled to anything that would help secure it and could be expected to actually reduce self vibration.
I checked them out: http://www.americanmusical.com/Item--i-AUR-GRAMMA-LISTRead the info on them there and about the application that they are designed for. Your typical sub used in live performances have to be light weight and moved before and after each gig. They resonant a LOT. And they will literally buzz across the floor. These pads put a damping layer between them and the floor to keep the floor from becoming a large resonating diaphragm.
Didn't know 300lbs was light....that's what their rated to handle. I use them and the improvement was day and night....I suppose a lot depends on how your floors are constructed....Jim
Jim,Standing waves as shown are wave lengths in a room which happen to match the room dimensions (at various multiples) that could +/- 20 dB frequency response errors. Below the Schroeder or "transition" frequency of a given room (typically 120 - 250 Hz), sound is dominating by standing waves (like waves going back and forth in a bathtub). An isolation base can do nothing for standing waves, only a 2nd out of phase bass generator located at the opposite end of the room can (like this rather innovative one):http://www.spatialcomputer.com/page9/page10/page10.htmlThe alternative is to use 3 or 4 subs strategical placed around the room.
Danny:I don't know if it softened them, maybe a less spl's. Without sounding too cliche, it sharpened them and they were able to go deeper cleanly. It is good that this isn't a fanboy thing and there are opposing viewpoints. It would have been more concise if I noted the flooring makes a difference as well on the onset. I have crappy floors, wood with Berber carpet.Jim
Ok, either way the Epic subs are really well built because they are super inert to where there is simply zero vibration from the cabinet. I'll post an impressions thread in a couple days. Very impressive sub, especially for the money.
