0 Members and 1 Guest are viewing this topic. Read 10850 times.
I have HSU ULS15's and they pack a huge punch. When listening to music I like to have them set at the lowest possible volume, otherwise there is just too much bass. Just my 2 cents.
I recently sold my rythmik fv12 due to lack of output.I'm looking for sub(s) that will be used almost exclusively for movies, but every now and then a music blu-ray.The sub I had prior to the rythmik, was a Dayton 15” Dayton titanic in a sealed box with a 1000W amp. It was close to having enough output, but I wasn’t happy with the sound quality. My room is fairly small. 12x14 with 14’ vaulted ceilings. I have a GIK 244 in each cornerInitially I won’t be using any type of EQ for the subs.I really enjoy very low frequency output. I’m willing to sacrifice max spl for sub 20Hz performance.Sealed or ported is fineThe sub(s) will most likely be placed between my speakers, so they can’t be tall. I’d 3’ at the absolute max. If there is a “perfect” sub for me that is over 3’ though, I might be able to buy some additional GIK panels to cover them up when listening to 2 channel, but I’d really prefer not to do this.I have the ability to build boxes. My Salks look so much nicer than anything I could build though, and I really don’t want to put one of my boxes next to them lol. I don’t think DIY is an option. A black finish would be fine.Budget is around $1,500, but if I could accomplish my goals for less, than I’m all for it. I’m also willing to buy used, so i’m open to those suggestions as well. SPL throughout my room seems very inconsistent with a single sub, so I’m leaning toward a dual setup.Thanks, and I appreciate the help
Hi Falconcry:Welcome to the Bass Place.Jim
Falconcry, I am a little unclear of what the SVS website is saying concerning the Dual SVS PC12-NSD sub-woofers.Is the price on the website the cost for two subs or one sub? If it is for two subs than it appears to be a bargain.
