Tung-Sol KT120 RAM Labs tubes in RM-9 - first impressions
0 Members and 1 Guest are viewing this topic. Read 4412 times.
hoppy08520
After learning that KT120 tubes could work in the RM-9 in this post, I ordered a quad of Tung-Sol KT120's from RAM Tubes. I finally got a chance to try them out tonight and wanted to share some initial impressions. (I would have posted a followup in the earlier thread, but since the subject line refers to the RM-200, I thought I would add a separate thread to avoid throwing anyone off.)
Keep in mind that I've only listened to around three albums (plus a handful of familiar songs from other albums), so this is by no means an exhaustive review. If I can, I'll come back in a few weeks and try to post a followup.
So, without further ado, here is what I heard:
  • The music sounded richer and creamier.
  • I felt a sense of euphoria I hadn't heard before.
  • In contrast with the Siemens EL34 tubes I had in the RM-9 earlier, the KT120s sounded less analytical and more "spacey" (not the best adjective) but not distorted or mushy. I wonder if this is the "tubey" sound that people use to describe certain amps and tubes.
  • The best complement I can give the tubes is that I wanted to keep listening to one song and album after another.
  • I'm not the type of audiophile who listens to a lot of equipment and tinkers with various tweaks and settings. So I generally don't gush about new gear. I wasn't really expecting to hear much of a difference because, so I was surprised at my reaction. I didn't really think I'd hear such a different sounds from different tubes in the same amp.
  • I will grant that sometimes "different" sounds "better" at first, just because sometimes our brains like something that sounds different to break up the monotony. So, I will try to post back again later after the tubes sink in more.
  • Per Roger's post, the four KT120 tubes put out 30 wpc each, for a total of 120 wpc. I sure didn't miss anything from the 220 (?) wpc that I had from 8 x EL34 tubes.
One thing I noticed is that after only a few hours, the tubes already have some flashing. In biasing the tubes, I turned the bias screw until the red LED adjuster lights just barely turn on, and then maybe half a quarter-turn (an eighth-turn) more. Is this normal?
For reference, I have a RM-9 MK2 that started out as a MK-1 until Roger upgraded it. I listen with the "medium" gain switch. The only tubes I've ever listened to it with are Siemens EL34.
Speakers: Spendor S100
Preamp: Anthem Pre 1
Cables: DH labs biwire cables
rbwalt
Re: Tung-Sol KT120 RAM Labs tubes in RM-9 - first impressions
« Reply #1 on: 18 Aug 2012, 01:48 pm »
sounds like you do not have many hrs on the new tubes.correct?  if so give them more time to settle in. a total of about 50 to 100 hrs should be ok then sit down for some serious listening. let us know then how things sound.
Ericus Rex
« Reply #2 on: 18 Aug 2012, 05:59 pm »
I think Roger recommends biasing the amp with all 8 tubes in, then removing either the front or back row.  I think you may be biasing the tubes far too high with only the quad installed.  However, I tried biasing this way and found my bias too high after dropping to 1/2 the tubes (cherry plates after a while!).  So I got this...
http://www.amp-head.com/product_info.php?cPath=21&products_id=70
...and now know exactly where my tubes are biased.  You can get a cheaper version from Amp-Head and you probably can find them on ebay.  I recommend getting one soon; KT120s are too expensive to burn out prematurely!
Roger A. Modjeski
« Reply #3 on: 9 Sep 2012, 08:04 pm »
In response to Hoppy. Note that I was quoting dissipation not output power. The output power of the RM-9 with 4 KT-120s will still be over 100 watts. Output power is more a function of the amplifier than the tubes in it as long as those tubes are capable of supplying the current needed. The KT-120 can easily supply that current with half as many tubes.  In fact, an RM-9 with only 4 KT-88s will do almost the full power, its just harder on the tubes from a dissipation perspective. Since the KT-120 has twice the dissipation of most popular tubes one can use half as many in my amp (I wont speak for others).
